Wheels Spacers - Suzuki Forums: Suzuki Forum Site
Old 11-03-2008, 03:38 AM   #1 (permalink)
Ethan is on a distinguished road
Default Wheels Spacers
hey wheel spacers... what do thay do and are thay good ,, what work is involved in puting them on ?? thanks
Ethan is offline   Reply With Quote Quick reply to this message
Old 11-03-2008, 06:51 AM   #2 (permalink)
clivey is on a distinguished road
Spacers give you a wider track (i.e. wheelbase will be wider) that accomplishes a couple of things:
1. Improve stability of the vehicle in off-camber (uneven) situations
2. Allow larger front tires to clear the leaf sprinsg and other undercarriage components during hard turns.
Spacers usually bolt on to the existing wheel studs. They have studs of their own onto which the wheel is then bolted.
Be careful about adding too much offset as it could give the axle more leverage against the suspension and lead to damage.
clivey is offline   Reply With Quote Quick reply to this message
Old 11-03-2008, 03:21 PM   #3 (permalink)
thanks mate , but would the wider track put more pressure on the axle.. and if i was to put spacers on what would be a safe size, my sierra is very much a stock sierra but i do want to change that
Old 11-03-2008, 03:46 PM   #4 (permalink)
I have run 1" wheel spacers for years with no additional wear and tear on the axles, bearings or wheel studs.
Old 11-03-2008, 03:49 PM   #5 (permalink)
awesome is there a difference in driving ???
Old 11-03-2008, 04:47 PM   #6 (permalink)
Lower center of gravity. The vehicle doesn't seem to shift (body roll) as much. I did this right after replacing the springs with a custom set for more control in the corners. I realize alot of that comes from the springs, but the wider stance has something to do with it too. It's easier to knock someone over if they have their feet together than if they have them shoulder width apart...
I also installed wider fender flares at the same time so the tires just come to the edge of the flares (no mud comes past the flares).
Old 11-03-2008, 06:32 PM   #7 (permalink)
Too wide a track could increase the axle's leverage on the spring mounts. What you should be careful about is the part of the axle between the spring/shock mounts and the wheel. If you make that too long by adding too much offset, the added leverage could bend your axle at the mount.
I have seen a slightly bent axle resulting from such a situation, but that was the result of hard use over an extended period. Then again it does happen so it would be best to avoid it if you can.
I've no personal experience with spacers, having used offset rims instead. I have a 1.5 inch offset on each rim and haven't experienced any problems so far. I'd say you'd be safe with 1 - 1.5 inches.
Old 11-03-2008, 06:49 PM   #8 (permalink)
The Toyota guys use a small gusset at the bottom of the axle where the tube meets the birfield bowl. That spot is where the axle housing is most prone to damage (bending).
Old 11-04-2008, 01:27 AM   #9 (permalink)
ok awesome so i guess the question is are they legal in QLD Australia
Old 11-04-2008, 08:15 AM   #10 (permalink)
Found pix of the gussets for anyone interested...
and installed...
These are from Trail-Gear Off Road Supply Toyota Jeep Samurai 4x4 Off Road Rock Crawling
