Go Back   Suzuki Forums: Suzuki Forum Site
Suzuki Forums: Suzuki Forum Site (https://www.suzuki-forums.com/forum-index.php)
-   Suzuki Jimny, Sierra & Samurai Forum (https://www.suzuki-forums.com/forumdisplay.php?f=156)
-   -   may be a fuel issue ? (https://www.suzuki-forums.com/showthread.php?t=265093)
romcd 08-06-2019 04:50 AM
OK i have a 1987 Suzuki samurai all original w/ soft top. the throttle keeps sticking and it really doesn't want to idle. i have tried to clean the carb and i haven't replaced to fuel filter but its on my to do list. any incite would be helpful
2013GV 08-06-2019 02:04 PM
what do you mean "sticking" ? as in sticks in a position and doesn't return?
romcd 08-06-2019 03:28 PM
Yes its almost like it's holding the throttle position at about 4grand, but if you rev it it will go back to idle speeds.
aquanaut20 08-06-2019 05:00 PM
Disconnect the cable and test if the throttle linkage is the issue, if not lubricate the cable..
.. Philip
romcd 08-06-2019 05:52 PM
Thanks for the advice I'll try that and see if it does the job. It doesn't help that it sat up for over ten years 😂
2013GV 08-06-2019 07:17 PM
this bit of information should have been given right at the beginning!!!!.
lube cable, pedal pivots and check linkage.
aquanaut20 08-06-2019 10:05 PM
GV2013, What, you no longer use the crystal ball???
... Philip
2013GV 08-07-2019 01:17 AM
... Philip
:o
I assume you are meaning me, 2013GV, not some other impostor?
nope, its packed away in storage with my patience, understanding and the ability to mind read.
Now I just use sarcaustic (yes, it is spelled correctly, its the ability to strip many layers with a single word) nuances to guide people into the right direction.
^_^
