87 Samurai Weber Conversion? - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
  • 1 Post By inthedirt
Old 07-07-2019, 06:40 PM   #1 (permalink)
Megaton is on a distinguished road
Default 87 Samurai Weber Conversion?
My stock sammy carb has just about had it. Has anyone here done the Weber conversion? Any tips welcome as to conversion kit, choke type, supplier, etc. are welcome.
Megaton is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 02:55 PM   #2 (permalink)
inthedirt is on a distinguished road
I bought a chinese knock-off Toyota 3k from Amazon for $50 and then bought a conversion kit off Ebay for another $120. Only a slight performance improvement but it idles super smooth now that the vacuum hoses a 99% removed. Starts much easier with the manual choke, too. Mileage didn't suffer a bit, but then, it didn't improve either. I get about 17-18 in town, about 20mpg on long highway stretches.
Megaton likes this.
Current Ride:
1987 Samurai, soft top
Previous Rides:
1985 SJ410, tin top
1986 Samurai, soft top
1996 Geo Tracker 16v, 4dr, 4wd, 5spd
1996 Sidekick Sport, 1.8L, 4dr, 4wd, 5spd
inthedirt is offline   Reply With Quote Quick reply to this message
Old 07-15-2019, 11:46 PM   #3 (permalink)
kw1997 is on a distinguished road
Well i am in the same bat. Looking for a SJ410 carb but original carb it is too expensive .
kw1997 is offline   Reply With Quote Quick reply to this message
Old 09-05-2019, 03:16 AM   #4 (permalink)
Niceperson709 is on a distinguished road
What precisely is in the "conversion kit" cos I've got a Chinese 3k knock off too and it bolted straight on and all I did was add studs from a 4k manifold and a Toyota carb spacer I did make a bracket for my throttle cable tho
Niceperson709 is offline   Reply With Quote Quick reply to this message
Old 09-12-2019, 12:38 PM   #5 (permalink)
Sorry, been down awhile from surgery......
I bought my 3k Toyota from Amazon for about $50 shipped. Didn't need to do anything to it prior to installation. Once installed, I used my vacuum gauge to set the idle mixture, then set the idle with my trusty Sears engine analyzer (from the 80s). Fast and easy install.
As for the ebay manifold kit, the seller included a choke cable and poly intake spacer that is cut exactly to the 3k carb. The bores are a little bigger and beveled. Without it, you'd have to modify your original spacer to make it work. He also includes the correct threaded fuel inlet adapter with nipple that he machines himself because this part doesn't exist in parts stores. There is 2 tygon fuel lines. One goes from the carb to the fuel pump, and the other goes to the vacuum port on the distributor. He includes a machined EGR block off plate and air cleaner adapter so that you can run your factory air cleaner assembly. If I didn't live in cold climates, I wouldn't worry about this but I wanted to keep the warm air pickup from the exhaust manifold. Lastly, he also includes all the rubber caps you need to block off the unused vacuum lines on the manifold.
Not gonna lie. The install was very straight forward and simple. Took longer to remove the stock junk than to convert to the 3k. What I noticed first was how much smoother the engine ran without all the vacuum leaks. Warm and cold starts are quick without all the cranking. Sometimes the fuel will evaporate out of the bowl on a warm day, so I just keep my foot on the throttle and it fires up, again, without all the cranking and building of fuel pressure again. The old Hitachi carb was always losing fuel pressure on me. Lastly, I didn't notice any differences in MPG or power. Was hoping to gain a little of both, but I didn't. If nothing else, its much cleaner under the hood and easier to tune. Plus, I'm getting ready to add a AMR500 supercharger (draw-thru) and there is no way I'd do that with the old Hitachi. Hope all this helps you with whatever decisions you're making.
Current Ride:
Previous Rides:
1985 SJ410, tin top
