86 Samurai Oil leak - Suzuki Forums: Suzuki Forum Site
Old 05-14-2019, 08:40 PM   #1 (permalink)
GBY010115 is on a distinguished road
Default 86 Samurai Oil leak
Have an 86 with an oil leak that looks like it is coming from camshaft cover near the oil filler cap. Is it common for the spout that holds the cap to leak? The oil is pooling just underneath the cap and I am going to replace the cap as a start but didn't know if the spout can fail as well.
GBY010115 is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 08:56 PM   #2 (permalink)
No, not common for the spout to leak unless someones used it as a handle to remove a stuck rocker cover. Check the PCV valve as well, this "leak" (if its from the cap) can be an indication that the crankcase is "pressurising" and oil vapor collects at the cap and seeps out around the cap seal.
Have you confirmed it is the cap thats leaking? or is it coming from the seal on the rocker cover bolt? they do go hard and crusty and leak as well and make a big mess. If its pooling by the filler neck but the neck is dry under the cap, it will be the cover bolt seal usually.
Old 05-14-2019, 09:03 PM   #3 (permalink)
I have not 100% verified it is coming from the cap but checked the bolts on the cover and they are tight. Also checked the seals on these bolts and all are intact from what I can tell. Thanks for the info on the valve, I will check that as well. In regards to the leak, when wiped and then drive the vehicle for a little bit the oil always pools next to the cap. With the vehicle sitting and not running leads to no additional leak or pooling of oil.
Old 05-14-2019, 10:47 PM   #4 (permalink)
can still be a hard rubber sealing washer on the cover. Just because the bolts tight doesn't mean its sealing.
To prove if its the cap, put a plastic bag over the cap and tie it onto the tube with a strong rubber band. If it fills with oil the caps leaking.
Next option if its not the cap is clean it thoroughly, wipe with a rag and some WD40 or similar, apply talcum powder to the tube and cover so its got a light coating, drive and see what gets wet.
Old 05-15-2019, 07:48 PM   #5 (permalink)
I will try the bag idea and get back to you. May be a day or two. Thanks for the help.
Old 05-18-2019, 01:02 PM   #6 (permalink)
Replaced the PCV and checked hoses back to the air cleaner for blockage. All checks out. More information about the problem, I have noticed if I run the engine with the oil cap off it is pumping air out like an air compressor. It is a significant amount of air, assuming that is back to your comment about pressurizing the engine
Old 05-18-2019, 01:43 PM   #7 (permalink)
there will be a fair amount of air being moved out the filler due to internal movement of components, as revs rise, the air volume being expelled tends to reduce as the pressure waves inside the block tend to cancel out.
If the PCV and hoses are clean, then I doubt blowby is the issue as there would be oil everywhere. Bag over the cap and see what it does.
Old 05-18-2019, 05:38 PM   #8 (permalink)
Bag over cap resulted in no oil caught in. So for that being the source I would assume that is put to bed. The oil drip is pooling under the transmission in the attached picture. There are two locations where it gathers and then falls. Would this be caused by the seal between the transmission and engine?
Old 05-18-2019, 07:48 PM   #9 (permalink)
is this the same leak you referred to in your first post? or another one?
Old 05-18-2019, 07:52 PM   #10 (permalink)
I believe it to be the same leak. Another picture for reference. Sorry for the confusion, I am a definite newbie to this.
Similar Threads
Thread Thread Starter Forum Replies Last Post
99 swift engine to 86 samurai ??? 86toad Suzuki Jimny, Sierra & Samurai Forum 0 07-01-2008 03:20 PM
For Sale: 86 Suzuki Samurai SledParty Classifieds - For Sale / Trade 5 03-10-2006 05:35 AM
For Sale: 86 Suzuki Samurai SledParty Recycle Bin 0 10-24-2005 01:37 AM
For Sale: 86 Suzuki Samurai SledParty Recycle Bin 0 10-24-2005 01:36 AM
For Sale: 86 Suzuki Samurai SledParty Suzuki Jimny, Sierra & Samurai Forum 0 12-31-1969 07:00 PM
