HELP...Alternator won't charge battery? - Suzuki Forums: Suzuki Forum Site
Old 05-05-2019, 08:36 AM   #1 (permalink)
csleger11 is on a distinguished road
Garage
Default HELP...Alternator won't charge battery?
Ok my 87 Sami has the GM CS130-105 amp Alternator upgrade.
The fuse is new and fine, the battery is new and fine, the alternator is new tested and fine.
Plug to alternator has red wire to battery + side and black wire to the white/red stripe wire of the sami.
Why will the alternator not charge the battery?
Any advice?
csleger11 is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 02:20 PM   #2 (permalink)
check wiring, Big terminal goes to battery and "S" terminal in the plug, "L" terminal goes to the charge lamp or ECU depending on vehicle its fitted to. If the dash lamp is blown then it won't charge, you may need to also jumper I and L together to get the regulator to activate, this must be via a lamp (charge lamp on dash) or an 85 ohm 5 watt resistor. electrical path for these connections is bat +ve, thru ign switch, thru lamp (or resistor) to L and I terminals.
Pic I have attached is the basic setup without the control feeds as described to make it work
S = sense voltage (senses battery volts to excite Alt)
I = Regulator ECU control via ign switch
L = Charge Lamp via ign switch
P = Rev Counter
Old 05-05-2019, 04:15 PM   #3 (permalink)
Garage
2013GV...Thank you.
What if the ECU has been deleted?
Old 05-05-2019, 07:17 PM   #4 (permalink)
Originally Posted by csleger11 View Post
2013GV...Thank you.
Don't worry, usually just join S to the big terminal which goes direct to the battery and take the "L" terminal to the ignition switch via a charge warning light
in rare cases depending on the regulator model you may need to join the I and L terminals together
The I terminal is there to allow the ECU to reduce the lad the alternator is applying to the engine when accelerating or is idling.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Alternator Low Charge ftdrisc90 Suzuki Jimny, Sierra & Samurai Forum 3 07-02-2017 09:17 AM
Hook battery charge backwards no power in cab [email protected] Suzuki Jimny, Sierra & Samurai Forum 8 09-05-2016 11:43 AM
Vitara 2001 wont charge the battery but the alternator works??? Im lost Pierre444 2G (1999-2005) Vitara & Grand Vitara 6 01-15-2015 09:52 AM
Battery will not hold a charge Jess1971 Suzuki Verona, Chevrolet Epica & Daewoo Magnus Forum 0 11-15-2010 10:02 PM
Battery wont hold charge? Only 22K miles on car? robblaw General Forenza & Reno Forum 14 02-13-2007 12:42 PM
