Timing on a 1.3 liter-Need Help - Suzuki Forums: Suzuki Forum Site
Old 04-09-2019, 06:39 AM   #1 (permalink)
csleger11 is on a distinguished road
Garage
Default Timing on a 1.3 liter-Need Help
I recently replaced the factory carb with a Weber 32/36 E-Choke and added a header.
Do I need to advance the timing? It is getting not so good mileage now and smells like fuel. It runs and idles fine.
Ant recommendations appreciated.
csleger11 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 08:14 AM   #2 (permalink)
There should be no need to change the timing, however, the smell of fuel and poor milage sounds like it's running rich - are you using the OEM fuel pump?
Old 04-09-2019, 11:39 AM   #3 (permalink)
Garage
No changed to a Holley 12-426 Mighty Mite pump. 25 GPH 1.5-4 PSI.
Old 04-09-2019, 02:09 PM   #4 (permalink)
have you checked your float level and the rest of your carb settings? fuel smell is a good indication of running rich. Idle circuit will not be operating when driving normally, so its very possible its over fuelling at road speeds.
Old 04-09-2019, 05:44 PM   #5 (permalink)
How is that Holley plumbed - is there a return line to the tank?
You're running a pump rated for 300 hp, on an engine with less than 100 hp, so a lot more volume than is required - with most pumps pressure & flow are inversely proportional so as you restrict flow pressure increases, and the webers are known to run rich with higher pressures.
You may need to add a fuel pressure regulator and get the pressure down to around 1.5psi
Similar Threads
Thread Thread Starter Forum Replies Last Post
1.8 liter sport ignition timing 97zuki Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 3 03-01-2013 10:08 AM
Need 5 speed manual for 1.8 liter Sidekick Neil Easley Classifieds - For Sale / Trade 0 12-08-2011 06:39 PM
Timing chain question for 2002 Tracker 2.0 liter tommyt 2G (1999-2005) Vitara & Grand Vitara 16 11-15-2010 07:37 PM
1.8 liter. I do need help! grey1 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 41 06-11-2010 01:17 PM
timing chain adjuster noise on 1996 sidekick 1.8 liter engine? dennisz763 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 5 09-29-2006 11:14 PM
