No High Beams - Suzuki Forums: Suzuki Forum Site
Old 04-02-2019, 09:42 AM   #1 (permalink)
inthedirt is on a distinguished road
Default No High Beams
Just picked up a 1987 Samurai, although not my first. Came with some horrendous LED lights that have been swapped out for some halogens. Was hoping to increase the amount of visible light for the driver while not blinding oncoming cars. That problem is now resolved, but I still have one lingering problem: no high beams.
I thought the problem may have been in the adapters that were used with the LEDs, but not so much. Low beams work as expected, the high beams will flash when the stalk is pulled, but I get nothing when the stalk is pushed to lock the high beams on. Just blackout. My multimeter is on the fritz and will need to order a new one, but can someone verify if the stalk switches the ground or the power, and which wires at the headlight plugs should be getting power when the switch is on and off. Thanks.
I'm guessing that I'm going to need a new switch assembly as the lights and wipers are slow to activate when rotated. Figure the contacts are dirty, and the switch is cheap enough, I may just replace it. Thinking of also building a relay system so the lights get their power directly from the battery rather than the factory system.
Current Ride:
1987 Samurai, soft top
Previous Rides:
1985 SJ410, tin top
1986 Samurai, soft top
1996 Geo Tracker 16v, 4dr, 4wd, 5spd
1996 Sidekick Sport, 1.8L, 4dr, 4wd, 5spd
inthedirt is offline   Reply With Quote Quick reply to this message
Similar Threads
Thread Thread Starter Forum Replies Last Post
High beams on with low beams J63812F General Forenza & Reno Forum 3 04-02-2018 01:09 PM
High beams and low beams GVs_2 2G (1999-2005) Vitara & Grand Vitara 10 12-16-2017 10:06 AM
No DRL and low beams .. but Hi beams work jeegro Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 27 06-24-2010 12:48 PM
High Beams Work, but NO LOW BEAMS!! Please help!! Schmeg Suzuki Forenza & Reno Forum 3 11-14-2009 08:05 AM
