Starter Relay Samurai SJ413 4WD year 1999 - Suzuki Forums: Suzuki Forum Site
Old 03-31-2019, 01:47 AM   #1 (permalink)
Wayne 77 is on a distinguished road
Default Starter Relay Samurai SJ413 4WD year 1999
Can anyone tell me where the starter relay is located on my Samurai SJ413, gasoline coupé with tarp 63 HP (spanish factory) ? Is it attached to the end of the starter or located somewhere else? Does anyone know where I can buy one. All the parts suppliers here is France are out of stock.
Thanks in advance,
Wayne 77 is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 03:53 AM   #2 (permalink)
Darrell.'s Avatar
To the best of my knowledge they don't have one as standard.
2005 Grand Vitara MT 1600se.
Old 03-31-2019, 12:28 PM   #3 (permalink)
only the main solenoid on the starter I believe, fed direct from the ignition / start switch
Old 04-02-2019, 02:18 PM   #4 (permalink)
Thank you for your help. I am not clear on what you mean. For me a relay is a device switching a low power circuit which triggers a high power circuit. In this case the switch on the steering column would close a low power circuit which would then open the full current of the battery to power the high current starter motor.
I don't know what you mean by "main solenoid". My guess is that you're talking about a solenoid that pushes the starter gear to engage the flywheel. However there must be some low current switching that releases the full power circuit to the starter to engage and turn the flywheel. This could be called a relay or a contactor (or a solenoid?).
Are you saying this low power switching circuit is included as an integral part of the starter motor ?
I'm attaching a photo of the device where the positive battery cable on my Samurai attaches to a cylindrical aluminum casing device (in the middle of the photo). It is altogether too small to be a starter motor so for me it should be the device that switches the full battery current to the starter. However I can't see where the wires from the switch on the steering column attach to it.
Do you recognize it ? Is it a detachable device or integral to the starter ? Is it what you call the main solenoid ?
Sorry for my ignorance of automotive terms and thanks again for your help.
Old 04-02-2019, 02:37 PM   #5 (permalink)
On a Suzuki Samurai, the starter solenoid mounted on the side of the starter serves two purposes - the first is to engage the starter bendix with the teeth on the ring gear of the flywheel (manual transmission) or flexplate (automatic transmission), and the second is to switch the starter current - this is the only "relay" in the starter circuit.
Old 04-03-2019, 02:12 AM   #6 (permalink)
I guess this means, since the solenoid doesn't look detachable, that to fix my problem of intermittent starting I'll have to replace the whole starter. Looks like a major job, with difficult access, probably best done in a Suzuki garage.
Thanks again for your help.
Old 04-03-2019, 03:03 AM   #7 (permalink)
the starter "solenoid" is removable, but only after the starter is removed from the vehicle. Check the small wire on the solenoid for a good connection, if you jump that terminal to battery + (or the battery lead on the big terminal) that will make the starter work and help confirm if its the starter and solenoid thats the issue, or whether its the ignition switch or wiring
Old 04-03-2019, 05:21 PM   #8 (permalink)
There are other causes of intermittent starting besides a defective starter relay/solenoid, and there are better ways to approach the problem besides replacing suspect parts.
Diagnosis should always come before part replacement - the last intermittent start problem I has was a defective battery - I kid you not - turn the key and it may or may not crank, try a couple of times and it would crank & start - start fine at home, drive down to the gas station to fill it, and no start after filling it.
Intermittent start covers a multitude of scenarios - what are the symptoms? What happens when you turn the key, does it crank, does it click, is there silence, do the dash lights go out?
A loose or poor electrical connection can be the cause of symptoms that could look like a defective starter.
Do you have a volt meter? What's the voltage at the battery terminals when you're trying to crank? at the starter motor terminal? at the starter solenoid terminal?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Turn signal mechanism Samurai SJ413 1999 1300cc gas convertible 4x4 Wayne 77 Suzuki Jimny, Sierra & Samurai Forum 1 10-13-2016 06:45 AM
Suzuki Samurai SJ413 - Fuel Consumption SpaceCale Suzuki Jimny, Sierra & Samurai Forum 8 08-09-2012 12:20 AM
Is SJ51 Samurai base on SJ413 platform? serv Suzuki Jimny, Sierra & Samurai Forum 2 02-27-2010 04:41 AM
Advice on Suzuki Sierra Wagon SJ413 1992 4WD dearot Suzuki Jimny, Sierra & Samurai Forum 0 05-17-2007 08:28 PM
1993 Suzuki Samurai SJ413 abedabun Suzuki Jimny, Sierra & Samurai Forum 0 08-04-2004 01:08 AM
