Bad tranny or Clutch - Suzuki Forums: Suzuki Forum Site
Old 03-24-2019, 02:19 PM   #1 (permalink)
mrm0518 is on a distinguished road
Default Bad tranny or Clutch
I need help trying to figure out what happened to my Samurai, I was in 1st gear whenever i switched into 2nd gear it was grinding but I didn't think nothing of it and kept going but i stopped to turn around put it into reverse and when I would let off of the clutch the motor would stall and i tried to give it more gas but did nothing.
mrm0518 is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 02:29 PM   #2 (permalink)
If you can't find the neutral position, then you have an internal transmission issue with the gear selector portion, as you are locked in-gear position.
Even if the clutch was completely shot, with the engine off you should still be able to find neutral and start the engine.
Old 03-24-2019, 02:33 PM   #3 (permalink)
It will go into Neutral but when I put it into gear it will not do anything, also there is a problem with the battery or starter cause it wil not start with the ignition the last 10 times I drove it I had to push it down a hill and manually start it.
Old 03-24-2019, 02:38 PM   #4 (permalink)
Oh! So WHEN it runs, you can select any gear, release the clutch and the engine continues running but the vehicle doesn't move?
Then the transmission is shot UNLESS the driveshaft turns, then you have broken differential or have axle issues. Check the undercarriage.
The random start issues are another subject all together and you should address those separately.
BTW...
Earlier you said that the engine would stall!
You need to better define the operational issues.
Old 03-24-2019, 02:43 PM   #5 (permalink)
You are not a 4WD with the transfer case in neutral (or destroyed) are you?
Old 03-24-2019, 03:22 PM   #6 (permalink)
Whenever it is running I can put it into gear then when I go to takeoff I will stall and it does not move at all.
Old 03-24-2019, 03:28 PM   #7 (permalink)
Assuming that the vehicle will push / roll freely (indicating that the brakes are not locked up, the e-brake applied, or the differential seized then the problem is in the transmission, as in locked-up.
Old 03-24-2019, 03:31 PM   #8 (permalink)
Also before the tranny was shot whenever I had it in neutral and it was running it would make like grinding/sctraching loud noise, any ideas?
Old 03-24-2019, 03:36 PM   #9 (permalink)
If in neutral with the clutch released, then yes transmission issues.
Drain and inspect the gear oil. Bet you'll see metal particle / parts evidence.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bad track Bad only starts up with starter fluid sdemers839 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 16 02-15-2013 08:09 AM
bad ECM or bad TPS o.O bigfoot061985 General Forenza & Reno Forum 0 06-28-2012 04:37 PM
Clutch start switch or bad clutch???? mallard79 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 18 10-04-2010 08:01 PM
93 Vitara, Bad, bad noises Dudmechanic Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 6 07-06-2010 09:00 AM
runs fine then bad then fine then bad.... Jay in Oregon Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 2 01-31-2010 12:49 AM
