no power to lights or ignition - Suzuki Forums: Suzuki Forum Site
Old 03-03-2019, 07:11 PM   #1 (permalink)
LHart420 is on a distinguished road
Default no power to lights or ignition
I have a 1990 model samurai 1.3L fuel injected. Bought it from a guy that was going to do the tracker motor swap and started disconnecting things but didn't remove engine . The eco was removed so i installed a new one. The truck has the clickity click relay, gm style alternator. I re hooked all the wires that i knew to do. I have a positive going from battery straight to starter and ground from battery to starter/block. Engine block is grounded to frame and firewall to frame. I added these grounds as i saw nothing grounding the motor or body. If i stick a test light to the negative on the battery and touch it to the motor itself the test light illuminates. Same deal if i touch any ground bolt on the firewall with the hot end of test light. Im sure this is something simple but I can't seem to figure out what the heck i have hooked up wrong!? the sammy was run ning when he parked it and been sitting fort about 2 years he says . If i turn the key over i have no power at all, no lights or wipers or starter anything. Ive got to be missing a hot powering the wiring harness and fuse block but looks like e everything is connected . HELP???
LHart420 is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 07:59 PM   #2 (permalink)
Figmo is on a distinguished road
Run a hot from the battery to the main post on the back of the GM alternator. And make sure the plug in the side is connected. One wire goes to the back post (same place you connected the battery), yhe other to the stock wiring harness.
Figmo is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 08:04 PM   #3 (permalink)
yea that's already done.
Old 03-04-2019, 12:54 AM   #4 (permalink)
Darrell.'s Avatar
Possible fuse link failure..
https://www.suzukiclubuk.co.uk/forum...hp?f=11&t=5983
2005 Grand Vitara MT 1600se.
Old 03-08-2019, 01:58 PM   #5 (permalink)
csleger11 is on a distinguished road
Garage
Check the fuseable link off the battery. I replaced the factory one with an in line replaceable 40 amp fuse. Mine had a similar situation.
csleger11 is offline   Reply With Quote Quick reply to this message
Similar Threads
Thread Thread Starter Forum Replies Last Post
No Accessory Outlet Power With Ignition Off geevee 3G (2006-2014) Vitara & Grand Vitara 12 06-01-2018 04:40 AM
2015 Vitara SZ-T - Retrofit automatic lights/turn lights off with ignition scamper82 4G (2015+) Vitara and Grand Vitara 2 02-12-2018 12:47 PM
Grand Vitara Power window, Blower, not working .,No power supply to power window fuse venki 2G (1999-2005) Vitara & Grand Vitara 6 10-16-2016 04:48 AM
97 tracker no ignition power kle67 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 10 01-07-2011 06:11 PM
no power to ignition module? lineman2002 Suzuki Jimny, Sierra & Samurai Forum 0 02-10-2010 07:44 AM
