No oil pressure - Suzuki Forums: Suzuki Forum Site
Old 12-12-2018, 08:06 PM   #1 (permalink)
Dexta57 is on a distinguished road
Default No oil pressure
I put a used 1.3 motor in my 87 samurai. I was told the motor was good- but once I installed the motor, it will not build oil pressure. Is there anything simple I may have over looked? Or did I buy a pig in a poke? TIA
Dexta57 is offline   Reply With Quote Quick reply to this message
Old 12-12-2018, 08:39 PM   #2 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
Sounds like you may have. What oil are you using? Do you actually have an oil pressure gauge on it?
2000 Tracker 2 dr. 2.0 Auto, 4x4. Sometimes it works, sometimes it makes me do the work.
USMC5811 is offline   Reply With Quote Quick reply to this message
Old 12-12-2018, 09:33 PM   #3 (permalink)
10w30. Mechanical gauge.
Old 12-13-2018, 12:35 AM   #4 (permalink)
disconnect gauge at engine block, disconnect ignition, crank.
oil at gauge outlet? yes? its at least pumping, get a new gauge, connect at block, start, run no more than 5 seconds if no oil pressure at this stage.
no? strip time to find out why.
Old 12-16-2018, 09:54 PM   #5 (permalink)
I removed the gauge from the block, no oil while cranking. I pulled the pan tonight. I had done a little work before I installed the motor. I did find the o-ring was missing on the oil sump. Not sure that will solve it but it wasn't right. Thinking I should put in a new oil pump while I'm at it. Any other thoughts?
Old 12-16-2018, 11:22 PM   #6 (permalink)
the o ring on the pump pickup? that will do it every time, they just suck air. Replace the pump while you're there. cheap insurance, at leats you know thats good then
