Multiple electrical problems - maybe one common cause? - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
  • 1 Post By 2013GV
Old 10-11-2018, 02:56 PM   #1 (permalink)
blickbox is on a distinguished road
Question Multiple electrical problems - maybe one common cause?
I'm having some problems with my 1985 SJ410. I owned this car for about 2 years, and drove maybe 4000km with it.
The biggest problems are:
1. Voltage gauge in dash seems low. See the amazing illustration I have attached. This could mean nothing though (defectiv gauge) - I have never seen it in the middle part of the yellow before.
The battery seems fine - It meassures 12.6V - even after staying parked in the garage for 3 months. When driving I meassured it to 13.6 - that is a bit low?
2. Brake lights doesn't work. All other lights works. But the weird thing, sometimes they will just start working again. Luckily, for no reason, they started working the day of last state inspection
Checked the sensor at pedal, and it moves fine.
3. Ignition will sometimes not light up dash when I turn the key to ON (not starting). Usually the dash light should come on immediately. But sometimes they will not light up for some time. They always come on at one point though, not sure if it's because I try to switch key on/off, or it's just a matter of waiting. Important to note though: When I turn key to ON and no lights show in dash - stereo will still play, and the starter engine will turn if I try - but engine will not start
Other things not working:
- 4WD light (worked when I first bought the car)
- Air fan - It worked one time, but after that never.
What I already tried:
I checked all ground wires I could find in the engine compartment. Also did a complete reinstall of battery terminals w/wires.
I looked at the grounds under the rear lights. I unscrewed some and cleaned, but some had stuck screw so I couldn't - but it all looks good...
What are some other ground points I should check? I can't really find any ground wires near the fuse boxes? I think there was one tiny wire infront of the door, is that all?
blickbox is offline   Reply With Quote Quick reply to this message
Old 10-11-2018, 06:30 PM   #2 (permalink)
Do you have a test-meter, do you know how to use it - because apart from the battery voltage I don't see one being used to diagnose the issue...
Let's start with the brake lights - that "sensor" is actually a switch, you check for voltage between ground and the switch terminals, with the pedal depressed and you'll know if the "sensor" works or not - sure it moves, but is there continuity?
Ignition switch - do you have voltage to the switch? Do you have voltage after the switch, when you turn it to the "on" position? Could it be a defective switch? Maybe a bad fusible link?
The 4WD light - maybe a blown bulb?
A VOM (if you're old school) or a DMM (for the youngsters amongst us) is essential if you're trying to troubleshoot an electrical problem, kind of eliminates the guess work...
Old 10-11-2018, 07:45 PM   #3 (permalink)
My first thought with the symptoms.....faulty ignition switch contact for the main "ign" circuit, that will explain low voltmeter, no dash lights and still having radio (acc contact) and crank but no start. Fusible link could be a cause but they usually get worse and turn into a permanent no power condition.
As Fordem suggests, get a multimeter on DC volts range and check the ignition contact to ground voltage at the switch and see if its the same as the "live" feed to the switch next time it has a problem and won't light up the dash lights. If theres a difference, then thats the first thing to change. Those contacts do wear out and fail. Wiggling the key works sometimes...its not a cure, but its a good indication that the switch might be faulty.
Brake lights, I think this could be a separate issue and could be connections or brake switch, or corroded fuse box....almost anything.
Fordem, not having a circuit diagram handy for the early 410's, do they have a "master" ign relay or just direct from the ign switch? I don't have one in the shop at the moment to look at.
Old 10-12-2018, 05:05 AM   #4 (permalink)
Thanks for the replies. I have a multi-meter, but I don't know how to use it other than connecting to + and - and read the voltage.
I'm just making it easy and order a new ignition switch, so I get two nice new keys also.
I unplugged the brake switch, and plugged it in again, and suddenly the lights work. Not sure it's that easy though, they worked earlier also. I just ordered a new brake switch, it was just $10, so might as well replace it. There's two wires connected - does it matter which is connected to which? Or is this simply a matter of completing a circuit when switch is released? (e.g, i can just connect the two wires and brake lights should light?)
I attatched a wiring diagram (not sure it applies for my car, since it's 85)
Multiple electrical problems - maybe one common cause?-1_86-88_samurai_wiring_diagram.jpg
Old 10-12-2018, 09:52 AM   #5 (permalink)
looking at the diagram as best I can, i suspect the ignition switch given what does and doesn't work from what you said earlier.
multi meter, easy to use, you have got the "voltage measurement " right, thats how it works, other handy feature is the ohms or diode test ranges, these are used for continuity, switch it to those ranges, short the leads should read 0 or pretty close to it (lead resistance comes into play here, maybe 0.2 ohms) and infinity or O/L when leads not shorted. Use this to check if wires are broken, broken wire will have infinite resistance, continuous wire will have very low resistance. Check a brake light bulb, that will show a value if good, and high resistance if blown.
Yep, it can be that easy to fix the fault sometimes, simply unplug and plug back in.
Brake light switch is just that, a switch. Wires don't care on that item, either way is fine. Adjustment is pretty straightforward as well. Set it so the lights are off when pedal is released, and they come on just before the brakes "bite" this way you can touch the pedal to warn the tailgating idiot behind you before the brakes actually start to work.
blickbox likes this.
Old 10-12-2018, 10:33 AM   #6 (permalink)
I don't think Suzukis of this vintage had any relays at all...
Old 10-12-2018, 10:35 AM   #7 (permalink)
I didn't think they did either, but i've seen some crazy things in a few here that have come in from Japan. Nothing like the equivalent NZ new version
Old 10-12-2018, 03:25 PM   #8 (permalink)
Darrell.'s Avatar
These are from the 410 workshop manual 99500-80002-01E.
They are for the 1985 onwards (plastic radiator grill).
The 82-84 is very basic wiring which I can post if need be (metal radiator grill).
This is from the workshop manual available in the UK so have no idea about variations worldwide.
2005 Grand Vitara MT 1600se.
