Anyone running Japanese Market Jimnys? - Page 2 - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
Old 08-30-2019, 08:10 AM   #11 (permalink)
Try plugging in your VIN from this page then.
https://catalogs.ssg.asia/suzuki/?lang=en
Old 08-30-2019, 10:26 AM   #12 (permalink)
mhall9150 is on a distinguished road
That's what I was trying. I enter the "CHASSIS NO." (JA11-281988), and the results are "not found". No combination of numbers found on the tags seem to be what it is expecting...
Has someone else got a VIN number from the same series vehicle that I can try? Thanks. Mike
mhall9150 is offline   Reply With Quote Quick reply to this message
Old 08-30-2019, 11:28 AM   #13 (permalink)
Vehicle Identification Numbers have been around since at least 1981.
The are in a standardized 17 (digits and capital letters) format peculiar to every vehicle. The number is minimally found on the dash and viewed thru the windshield IF you have one, and often displayed on other key pieces of the automobile to include glass and body.
I was hoping that the first link I sent you;
https://catalogs.ssg.asia/suzuki/?la...lkPT0xOA%3D%3D
That displayed...
Model Series
Market All Regions Jimny
SN413
SN415
The 413 and 415 relates to engine size I believe. 4 cyl, 1.3L for instance on the first one. Click on those links for further info.
You will then see stuff like:
SN413V-4 (SANTANA)
SN413V-5
SN413V-6 (E02,E05,E10
Santana being the Spanish Factory and the "E" codes break down to various country code of origin.
Maybe that will help. Beyond that, I'm as lost as you are.
Old 08-30-2019, 02:23 PM   #14 (permalink)
ok, the blue plate in the pic is the data plate which is where I think you have found your chassis number. I have added the (generic) VIN decode label so you know what you're looking for. Some of the japanese models had the VIN on drivers side under a small plastic cover on the door sill, some on the dash where windscreen meets dash visible thru the screen, some stamped into the bodywork under the bonnet, either firewall, or across the front rail by the radiator. If yours is an import, it will be there, and may be painted over if its stamped into the bodywork.
good luck finding it, you will get to know your wee truck well after a thorough cleaning to expose it hehe
my vin numbers start JSAJTAAV00XXXXXX AND JSAJTDA4V00XXXXXX
so yours i'd expect if an import should be JS.......
Anyone running Japanese Market Jimnys?-vin-decode-1.jpg   Anyone running Japanese Market Jimnys?-suzuki_jimny_turbo_1993_original.jpg
2008 Swift M15A
Old 08-30-2019, 04:30 PM   #15 (permalink)
Thanks for sticking with me and trying to help. I'm familiar with the typical VIN label, but I don't find one anywhere on this vehicle. It may be that since this was built in 1994, and was imported by one of the so-called gray-market importers just this summer, it may not have the 17-character standard VIN, as it was not originally manufactured for export. There is no evidence of the vehicle being repainted.
I also have the original export documents, which are mostly in Japanese. Using a translator app on my phone, I have read through the papers, finding no other reference number for this except the chassis number. My next step will be to translate the various plates and labels on the body, as well as under the hood (bonnet?) Maybe I'll discover something interesting.
Thanks again...
Mike
Old 08-30-2019, 05:31 PM   #16 (permalink)
Thanks again...
Mike
it will have a VIN, they are allocated at the factory and the vehicle will have one, try these locations as well.
Chassis/VIN Plate
The Jimny VIN number can be located On the left side of the engine compartment behind the battery riveted to the bulkhead
Visible VIN
not usually unless designated for US market, then visible thru screen
Stamped Number
stamped into the rear right hand chassis viewed just behind the rear wheel
vin is bottom of the plate in attached pic.
2008 Swift M15A
Old 09-03-2019, 10:58 PM   #17 (permalink)
Well, I appreciate that you are convinced that there is a VIN number somewhere on this Jimny, but I'm not so sure. Since your last post, I have removed both rear wheels, searching the frame for a stamped on number. I've crawled under it, checking everywhere it could be. I've pulled up the carpet, looking for some concealed tag. And I have scoured under the hood for some elusive label. No Luck! And the example chassis tag looks like one installed for US import. My tag looks like this:.
Sent from my Pixel 3 using Tapatalk
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
