Sierra with a 1.6 16v g16b conversion - Suzuki Forums: Suzuki Forum Site
Old 05-26-2018, 08:22 PM   #1 (permalink)
JoeD is on a distinguished road
Default Sierra with a 1.6 16v g16b conversion
Any help will be Much appreciated I bought this car with the conversion already done I will just one wiring harness not completed so I got the wiring harness re wired by Suzie Tech in Hornsby I still can’t get this car to start no matter what I try I have great spark and perfect fuel pressure as I have just change the fuel pump reading at 40 PSI while cranking dropped 30 something I only get injector pump sometimes intermittent I feel like it injector pulse cutout for some reason don’t know if the TPS,And when I check Engine light it reads “12, As I have another Baleno that I drive around daily I have changed all the accessories like injectors coils and plugs and senses in my car runs fine,
JoeD is offline   Reply With Quote Quick reply to this message
Old 05-27-2018, 02:55 AM   #2 (permalink)
Hi I have a g16b with no start have good spark from the coils but when I took my air intake off to see if I get injection spray I get spray from 1 and 4 I know my injectors are good because I tested them and they all spray fine under pressure and voltage but while cranking only 1-4 spray and some times 2 or 3 but not in firing order,, I bought the car with this motor in it and got the whole thing re wired professionally and voltage on all sensors are all correct, it is a coil g16b and cam timing is set on E and crank is tdc, I’m thinking could this crank teeth? I’m so frustrated
