A/c condenser replacement - Suzuki Forums: Suzuki Forum Site
Old 04-21-2018, 09:19 PM   #1 (permalink)
jbwilli is on a distinguished road
Default A/c condenser replacement
I recently purchased a Samurai A/C Donor kit to add A/C to my 1990 Samurai. The Condenser is 1990 era R12. The fan and its frame are held to the condenser frame via 4 bolts. I removed it with no problem. The left and right mount brackets appear to be spot welded to the condenser frame??? Does the condenser come out of its frame? If I opt to replace the condenser with new, how are the mount brackets removed? I see no new direct plug and play replacement condensers with the side brackets included. Any one an answer? THANKS!
jbwilli is offline   Reply With Quote Quick reply to this message
Old 04-27-2018, 06:29 AM   #2 (permalink)
I answered my own question! After more study I found 4 screw (2 ea side) that hold the side brackets onto the condenser coil. I had to soak the threads in Kroil (aviation rust penetrant) and shock the screw heads in a ccw direction with a small sharp pointed chisel and a small hammer to get them the break loose. I had to carefully pry the side brackets open a bit so they would slide off to the outside. In the end, my local radiator/condenser shop convinced me to clean the condenser externally with a good degreaser and then internally with AC flush. I also cleaned the side brackets. I put a light coat of black paint on the condenser coils and heavy coat on the side brackets. It looks like new externally. Next I will flush the condenser internally with the AC flush. Looks like I will be able to save this condenser!
