Argh! Battery drain...where to start... - Suzuki Forums: Suzuki Forum Site
Old 02-12-2018, 04:31 PM   #1 (permalink)
Norad2000x is on a distinguished road
Garage
Default Argh! Battery drain...where to start...
It looks like my Sammy has developed an electrical drain somewhere. If I don't drive it for ~3 days, it won't turn over.
The battery is new- got it about 3 months ago...
Where do I even start to trace this issue?
I have installed some aftermarket gauges, etc, but I thought those were turned off via ignition.
What power circuit remains on after the key is out? The radio? How do I check if those are draining?
Norad2000x is offline   Reply With Quote Quick reply to this message
Old 02-12-2018, 05:45 PM   #2 (permalink)
Darrell.'s Avatar
This explains things quite well. Disconnect the meter between fuse swapping as if left connected in circuit for to long the multimeter internals can get too hot. I found this out when testing the brother in-laws car and thought my meter smelt and found a very overheated/discoloured resistor on it's circuit board.
You can use a crude setup of a 12v bulb (low wattage) instead of the meter, it will light up until you remove the fuse for which ever circuit has the drain on it.
https://www.wikihow.com/Find-a-Parasitic-Battery-Drain
2005 Grand Vitara MT 1600se.
Old 02-12-2018, 10:20 PM   #3 (permalink)
avisitor is on a distinguished road
There are many videos on youtube to help one begin to find the cause of the parasitic drain.
avisitor is offline   Reply With Quote Quick reply to this message
Old 02-14-2018, 01:08 AM   #4 (permalink)
Garage
Thanks guys! I'll give this a try and see what happens!
Old 04-16-2018, 11:11 PM   #5 (permalink)
Garage
Well, I used meters and bulbs and think I found the issue...
The stereo's power cable connected intermittently when I wiggled it. Whenever it reconnected to power, it would draw power as the CD player power cycled.
Other than that, I couldn't detect any other current drain. So, hopefully that's the problem =/. I installed an electronic power disconnect just in case.
Old 04-17-2018, 02:12 AM   #6 (permalink)
Donewrken's Avatar
. . . . and are they off with the switch?
Oh no!
Another parasitic drain!!
What kind of an electronic power disconnect?
Curious minds need to know the details, Thanks
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 04-17-2018, 04:03 PM   #7 (permalink)
Garage
I installed this one:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's the only non-automated electrical disconnect I could find. The build is pretty good- beefy contacts, etc. However, I now need to remember to switch the power off EVERY TIME. Otherwise, the switch will eat power at 0.5A and eventually kill my battery...
Old 04-17-2018, 05:58 PM   #8 (permalink)
Donewrken's Avatar
Thanks for the info and link.
No worries, not a parasitic drain, not electronic but electromagnetic.
Don
