Fueling Issues - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Old 02-08-2018, 07:43 PM   #1 (permalink)
Mroberts is on a distinguished road
Default Fueling Issues
I recently picked up a 1990 samurai which had been sitting up for who knows how long. I replaced the fuel tank, pump and filter in hopes that the fueling problem would be fixed. Pump is definitely running but no fuel is being squirted into the throttle body. Not sure what my next step should be. Test injector? Any help would be greatly appreciated. (Btw the engine runs on starting fluid so I know it has spark.)
Mroberts is offline   Reply With Quote Quick reply to this message
Old 02-08-2018, 08:26 PM   #2 (permalink)
avisitor is on a distinguished road
Would check to see if throttle body is receiving power and ground
If not then check for blown fuse or bad relay
avisitor is offline   Reply With Quote Quick reply to this message
Old 02-10-2018, 12:15 PM   #3 (permalink)
Darrell.'s Avatar
Does the check engine light come on. Not sure how many things can set this on the injection models.
2005 Grand Vitara MT 1600se.
Old 02-10-2018, 01:47 PM   #4 (permalink)
Donewrken's Avatar
In this I read the car was parked due to a fuel problem.
Then you replaced those parts in hopes that the fueling issue would be resolved.
My question would then be, is the new fuel pump operating when you turn the key.
If not, it could be the fuse, relay and possibly the ECU.
As Bex suggested on a similar issue, replacing the capacitors resolved the issue, I do not know for certain if that would pertain to your case.
Only a suggestion.
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 02-10-2018, 02:24 PM   #5 (permalink)
Yes the check engine light comes on. I put a fuse in the diagnosis slot but the check engine light didnít flash
Old 02-10-2018, 04:11 PM   #6 (permalink)
Darrell.'s Avatar
I don't think these throw a code for the injector so I guess you could at least check it's resistance.
