Oil leak on top end - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Like Tree1Likes
Old 12-29-2017, 09:11 PM   #1 (permalink)
samuraijack is on a distinguished road
Garage
Default Oil leak on top end
I have seriously went through the entire thing and canít find where this leak is coming from!!! I see the area it dripping, but not able to find whatís causing it.
Hereís the video. https://youtu.be/IyDEE8ZHDKk
____[SIGPIC][/SIGPIC]____
[FONT="Comic Sans MS"][SIZE="2"]I'm ready for fall! [COLOR="Black"][/COLOR][/SIZE][/FONT]
samuraijack is offline   Reply With Quote Quick reply to this message
Old 12-29-2017, 10:02 PM   #2 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
Not sure if your valve cover seal is like the one on the 2.0 but I have a leak at the rear of the cover where the little half moon seal piece is.
Good luck
USMC5811 is offline   Reply With Quote Quick reply to this message
Old 12-30-2017, 12:59 AM   #3 (permalink)
Garage
Good luck
Iíll check it out, any reason why it would be shaking so much?!
Old 12-30-2017, 08:10 PM   #4 (permalink)
USMC5811's Avatar
That can be a real can of worms. Start a new thread on that topic. Fordem is pretty good on diagnostics so you can figure it out.
Old 12-31-2017, 12:38 PM   #5 (permalink)
Darrell.'s Avatar
The fuel pump has a breather hole on it. It may be worth checking if leaking oil is coming from
there.
2005 Grand Vitara MT 1600se.
Old 12-31-2017, 12:46 PM   #6 (permalink)
Darrell.'s Avatar
Scrub that. The pipe to the left is the breather and it's not coming from there. It could be the fuel pump gasket though.
Old 01-01-2018, 05:30 PM   #7 (permalink)
Garage
Out of the fuel pump gasket? Thatís an easy check. Iíll do that when I get back home
Old 01-13-2018, 06:20 AM   #8 (permalink)
Zuki671 is on a distinguished road
Default Camshaft seal
Might be your aft cam seal. Mine was leaking on the same spot.
samuraijack likes this.
Zuki671 is offline   Reply With Quote Quick reply to this message
Old 01-13-2018, 06:23 AM   #9 (permalink)
Default Shaking
Your motor has a leak which means air is also leaking air is being lost through the leak. This screws up your vacuum as well, you can lose a small amount of vacuum and experience a significant amount of loss in power which can cause turbulence.
Old 01-13-2018, 10:49 AM   #10 (permalink)
Garage
aft cam seal... does that require the top end be pulled?
