Washed motor - now have starting problems - Suzuki Forums: Suzuki Forum Site
Old 12-17-2017, 05:37 PM   #1 (permalink)
Ashmenz0 is on a distinguished road
Default Washed motor - now have starting problems
Hi Everyone
I have a 1999 Jimny that has an oil leak at the back (top) of the motor. After degreasing and washing the motor down to identify where the leak is I am now having starting problems.
I removed the crank angle sensor and cleaned and dried it, and it started first go. Then this morning it started first go and ran perfectly to get it out of the garage but now it will not start at all.
The CAS was replaced about 6 months ago and hasn't missed a beat since. The only reason it was replaced was that every now and again power would die for a second or two and come back on.
I look forward to your thoughts/comments
Ash
Ashmenz0 is offline   Reply With Quote Quick reply to this message
Old 12-17-2017, 06:46 PM   #2 (permalink)
aquanaut20's Avatar
You have some condensation/water causing a short to ground..
Dry well, powder and change diaper.. remember it your baby!
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 12-17-2017, 07:38 PM   #3 (permalink)
What engine does your 99 Jimny have? G series or M series?
Did you use a pressure washer?
Remove the coil packs, make sure there's no moisture down in the plug wells.
Old 12-17-2017, 11:15 PM   #4 (permalink)
avisitor is on a distinguished road
Ash
If it hasn't missed a beat since .. then why start this thread?
My comment would be to not clean the engine like that again ... lol
avisitor is offline   Reply With Quote Quick reply to this message
Old 12-18-2017, 01:20 AM   #5 (permalink)
rasmeidirtrider is on a distinguished road
Cover your valve cover with plastic bag to prevent water from penetrating the coil packs and the plug wells. That is the real issue!
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4spd auto, 4x4, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R16 Tires.
rasmeidirtrider is offline   Reply With Quote Quick reply to this message
Old 12-18-2017, 03:53 PM   #6 (permalink)
Hi Fordem
Thanks for your sensible response. It has a G series motor, I did use a pressure washer at the carwash. I have removed coil packs, all plugs and used WD40 and carby cleaner to remove as much residue of water that I can see & feel.
I started the car this morning. It ran for about thirty seconds or so and then completely died. Would not re-start in the next 15 minutes (and I had to get to work).
Any further thoughts would be greatly appreciated.
Ash
Old 12-18-2017, 07:50 PM   #7 (permalink)
check the fuses again
Make sure nothing is blown
Did you get any water into the ECU?
Old 12-18-2017, 08:21 PM   #8 (permalink)
Remove the coil packs again. Inspect the boots for crack and the spring inside them and stretch them by hand to make more contact.
Old 12-18-2017, 11:36 PM   #9 (permalink)
No water in ECU, fuses are good. Have removed the coil packs and can't see any cracks or water. I think they are making good contact as it starts really well, runs smoothly. Problem is it's only for about 40 seconds and then it dies as if I've turned the key off.
Old 12-19-2017, 03:32 AM   #10 (permalink)
Then the cause of the problem is something else. In the your first post, you mention about replacing CAS!!
