Help !! K&N pod filter intake - Suzuki Forums: Suzuki Forum Site
Old 12-11-2017, 03:26 AM   #1 (permalink)
Matthewvw is on a distinguished road
Default Help !! K&N pod filter intake
Hi there guys.. I need some advice... During the weekend I tried to install a k&n pod filter on my 1.3 Suzuki jimny. It was a complete fail. I ran a pipe to the maf and which then linked to the cone filter. Everything was sealed off and the maf sensor was air tight and was secure vertical the way it should be. I was quite confused because I had quite an unexpected result. at first my car would just die after ignition and if I gave it petrol it would feel very flat. I then changed the idle body and my car began to surge when idling and the accelerating was still flat and delayed. Can someone please give me some advice on the matter
thanks
Matthewvw is offline   Reply With Quote Quick reply to this message
Old 12-11-2017, 03:46 AM   #2 (permalink)
Default the setup
Click image for larger version
These are the two images... please just bear in mind when i did have it on the filter box was out and has currently been setup up to default again. Hope this makes it more visual
Old 12-11-2017, 08:00 AM   #3 (permalink)
urbex is on a distinguished road
Works fine with the stock filter box set up?
Your description of the issue sounds like you still had either a vacuum leak, or a source of air getting in behind the MAF, which made the ECU think the engine was getting less air than it really was, in turn causing a lean issue.
Alternatively, are you sure all sensors were installed AND plugged back in after the K&N install? I'm not familiar with the set up of your Jimny, as they were never offered in the US, but using my Vitara 2.0 for example, as I fitted it in my Samurai without the factory filter box, there was no place for the intake air temp sensor to go, and I had to re-route the fresh air intake for the PCV system. Though granted, neither of these would cause the issues you describe.
If by "idle body", you're referring to what we would call the "throttle body", the part where the throttle cable would attach, perhaps you either forgot to plug in the Throttle Position Sensor, or it's faulty on one or the other body?
1987 Samurai - SOA, 31s, 2.0L swap, ZOR bumpers/cradle, 6.5 t-case gears - rock crawler
1990 Ford F350 CCLB DRW 4x4 7.3L Banks turbo - tow pig
1959 International B-162 - future heavy hauler
1986 Chevy K5 - 489/4L80E/35s
urbex is offline   Reply With Quote Quick reply to this message
Old 12-11-2017, 10:18 AM   #4 (permalink)
aquanaut20's Avatar
This is way beyond your pay grade, restore to factory and you will be mobile again..
K&N filters are just an ego booster, do nothing positive for engine..
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 12-11-2017, 07:42 PM   #5 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
Put the stock air box back in and just use a K&N made for it. It will probably make MORE power than the pod. The stock box uses cold air, not the 200 degree engine bay air that the pod will be sucking.
USMC5811 is offline   Reply With Quote Quick reply to this message
