Engine Cleaning Help - Suzuki Forums: Suzuki Forum Site
Old 12-10-2017, 01:54 AM   #1 (permalink)
Sponges is on a distinguished road
Default Engine Cleaning Help
I have an oil leak that I'm going to fix. Wondering if there is a recommended spray that works well to clean the engine, I also need to clean my oil pan. I know people use brake cleaner.
Sponges is offline   Reply With Quote Quick reply to this message
Old 12-10-2017, 03:15 AM   #2 (permalink)
Darrell.'s Avatar
I used this many years ago, worked great. Just hope they haven't made it too environmentally friendly and not work any more
I used the brush on
2005 Grand Vitara MT 1600se.
Old 12-10-2017, 07:51 AM   #3 (permalink)
Your choice of spray degreaser and a garden hose with good water pressure, I strongly recommend against the use of a pressure washer.
My choice of degreaser is "purple blaster", and if you go with that, make sure to wear gloves - I find it also does a great job at removing the skin oils.
Brake (or carburetor) cleaner can be used, I find it an expensive approach - but I will use it for areas where I would rather not use water - electrical stuff, engine internals when I'm not tearing the engine down completely - but on the outside of the engine before I open it, no, there are less expensive ways.
Old 12-10-2017, 08:10 PM   #4 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
Usually the stuff on the pan is caked on. Scraper works to get rid of thick hard stuff. If you use a spray on you will will have to wipe it down. Like Fordem says, pressure washer is not kind to electrics. Kitchen degreaser and paper towels/shop towels work well on areas that are just dirty. Elbow grease is your friend.
USMC5811 is offline   Reply With Quote Quick reply to this message
Old 12-10-2017, 09:31 PM   #5 (permalink)
Donewrken's Avatar
My favorite for the last 6-8 years is "Oil Eater", I buy it in 5-gallon pails.
A 16 oz spray bottle and you thin it 50/50 with water or hot water.
Spray it on and next day rinse with water, more if needed.
For aluminum blocks, etc. for the burnt on/caked on Easy Off Oven Cleaner.
cover wires, anything not needing to be cleaned, hoses.
Spray two or three heavy coats and in a few hours, or the next day hose it off.
It cannot be too toxic, it's used in ovens.
I've used it for over 20 years without any issues.
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
