1990 EFI idle speed - Suzuki Forums: Suzuki Forum Site
Old 11-15-2017, 11:50 AM   #1 (permalink)
DocPaul1 is on a distinguished road
Default 1990 EFI idle speed
Hi gang.
What should the approximate idle RPM's be for 1990 EFI Sammi if the outside air temp is + 45 degrees F ?
Mine seems idle awful fast (won't have the tach put in until next Friday). It does slow down when the engine temp goes up, but at dead cold start it seems way too fast.
If it is too fast, what can be done to slow it down ( dead cold RPM's ) ?
Darrell, I'm sure you can answer this one.
Doc.
DocPaul1 is offline   Reply With Quote Quick reply to this message
Old 11-15-2017, 04:19 PM   #2 (permalink)
Darrell.'s Avatar
Idle speed when warm is 800rpm + - 50 and 1000rpm + - 50 with AC on. I can only assume when cold the ECU uses the idle speed control valve to increase the RPM until the water temperature increases. I don't know what the RPM should be on cold start up
2005 Grand Vitara MT 1600se.
Old 11-15-2017, 04:54 PM   #3 (permalink)
Thanks again Darrell.
Doc.
Old 11-16-2017, 03:43 PM   #4 (permalink)
Got the tach in and engine RPM is correct at all temps. I guess I thought it was running faster than it was.
Problem solved. Thanks to all.
