Adding tach to 1990 Sammi - Suzuki Forums: Suzuki Forum Site
Old 10-29-2017, 01:52 PM   #1 (permalink)
DocPaul1 is on a distinguished road
Default Adding tach to 1990 Sammi
I have a 1990 8V EFI 1.3L engine. I have looked at all the wiring diagrams for the Sammi but the only one that shows the actual wiring I have, the color codes are blurred so bad I can't read them.
Any help on which lead I should tap into for the tach signal would be greatly appreciated. Also the location for that lead.
Thanks in advance.
Doc.
DocPaul1 is offline   Reply With Quote Quick reply to this message
Old 10-29-2017, 02:19 PM   #2 (permalink)
Darrell.'s Avatar
The brown wire from the noise suppressor goes to the tach.
2005 Grand Vitara MT 1600se.
Old 10-29-2017, 02:21 PM   #3 (permalink)
Darrell.'s Avatar
Grab a copy of this for future use
Old 10-29-2017, 05:54 PM   #4 (permalink)
Thanks Darrell.
I was not looking at the correct unit that is called the Radio Noise suppressor. I now see the Brown wire that will be used as the tach lead.
Thanks again Darrell for the wiring diagram and your help.
Doc.
Old 11-08-2017, 10:55 AM   #5 (permalink)
Hi Darrell.
I hooked up a tach (battery and ground) and the tach signal lead to the Brown lead on the noise suppressor and my tach just wanders all over the place with various numbers on the display. I am really at a lose as to why this is happening and also am I on the correct lead ??? Please advise. Thanks in advance
Doc.
Old 11-08-2017, 01:07 PM   #6 (permalink)
Darrell.'s Avatar
Are your using an aftermarket tach, maybe it doesn't like the noise suppressor, I'd try connecting the signal lead straight on the coil negative terminal or brown/white wire.
Old 11-08-2017, 02:40 PM   #7 (permalink)
I'll try that now and get back to you.
Thanks Darrell.
Old 11-08-2017, 02:50 PM   #8 (permalink)
I tried the - coil lead (Br/Wh) and had the same effect . The tach is good as I tried it on another car (not a Samurai) and it works.
Any other suggestions ??
Old 11-08-2017, 02:51 PM   #9 (permalink)
This is an EFI Sammi if that makes a difference.
Old 11-08-2017, 03:00 PM   #10 (permalink)
Darrell.'s Avatar
I'm afraid I don't
