89 sierra rear wheel bearing probl - Suzuki Forums: Suzuki Forum Site
Old 07-05-2017, 05:09 AM   #1 (permalink)
Bradb65 is on a distinguished road
Default 89 sierra rear wheel bearing probl
Hi I've refitted new bearings, when I do up the bearing backing plate it cause the axle to lock up, same on both sides, bearings same width as old ones . Can anyone help please
Bradb65 is offline   Reply With Quote Quick reply to this message
Old 07-05-2017, 05:20 AM   #2 (permalink)
Check to see if the bearing spins freely with the axles removed, that the bearings are fully advanced and seated against the axle shoulder.
Then make sure that you didn't mix right and left axle assemblies, as in some applications they are of different lengths.
Welcome aboard too Brad.
Old 07-05-2017, 05:33 AM   #3 (permalink)
Darrell.'s Avatar
Didn't leave the spacer rings out? If they were fitted before, some bearings don't require them.
Old 07-05-2017, 05:56 AM   #4 (permalink)
Thanks guys, when I fit the axles without tightening the backing plate, it all turns freely, as soon as I tighten the backing plates it locks up, the bearings move freely out of the diff, it's just a bearing and lock ting, I've noticed the bearings protrude approx 1 mm from the diff housing. Ive measured the old bearing against the new one and they are the same
Old 07-05-2017, 06:33 AM   #5 (permalink)
The retaining plate should contact only the outer race portion in order to pinch / secure the bearing in the axle tube, thus keep the whole bearing from turning.
Are you using the outer retainer plates that were removed originally? The retainers weren't flipped or damaged in the bearing to axle assembly (pressing) process, right?
What is the reasoning for even replacing the axle bearings? The cause may help us to determine the existing issue.
Was the correct axle bearing retainer used? ABS and non-ABS vehicle retainers differ as an example.
Old 07-05-2017, 06:45 AM   #6 (permalink)
See this other site thread as well. It may not depict your exact model, but Zuki axle bearing assemblies differ little.
Rear axle bearing install - Zukikrawlers
Our forum's reference thread is pretty beat up with the loss of Photobucket third-party pic hosting.
https://www.suzuki-forums.com/2g-1999...ment-99-a.html
Old 07-05-2017, 03:20 PM   #7 (permalink)
Darrell.'s Avatar
If your bearings are not the type that use a spacer you have to make sure the inner race protrusion is facing the correct way (towards wheel).
Welcome to the forum by the way
2005 Grand Vitara MT 1600se.
Old 07-05-2017, 03:23 PM   #8 (permalink)
Darrell.'s Avatar
Found an old diagram I did years ago.
