Valve adjustment question - Suzuki Forums: Suzuki Forum Site
Old 07-03-2017, 05:54 AM   #1 (permalink)
DocPaul1 is on a distinguished road
Default Valve adjustment question
Hi gang.
Can the valves on a 1.3 8V be adjusted WITHOUT removing the timing belt cover ?
Doc.
DocPaul1 is offline   Reply With Quote Quick reply to this message
Old 07-03-2017, 09:10 PM   #2 (permalink)
Azelgin's Avatar
YES
1) Remove cylinder head cover.
2) Remove ignition timing check window
rubber plug from clutch housing of transmission
case.
3)Turn crankshaft clockwise (viewing from
crankshaft pulley side) to the extent that
line @ “T” mark punched on flywheel
is aligned with match mark on
transmission case, i.e. No. 1
cylinder piston reaches TDC position.
4) Remove distributor cap and check that rotor
is positioned with rotor blade to #1 plug wire. If rotor is
out of place, turn crankshaft clockwise
once (360”). In this state, check valve lashes
at valves #1 intake, #1 exhaust, #2 intake, #3 exhaust. Rotate crankshaft
exactly one turn, and check valve lashes at valves #2 exhaust, #3 intake, #4 intake, #4 exhaust.
Old 07-05-2017, 04:41 PM   #3 (permalink)
Thanks Azelgin.
Doc.
