dies everytime i hit a bump gas!!!! - Suzuki Forums: Suzuki Forum Site
Old 04-16-2008, 12:25 AM   #1 (permalink)
casperfast is on a distinguished road
Default dies everytime i hit a bump gas!!!!
ok, i have an 86 samurai. everytime i hit a bump while im driving it, it dies. i pop the hood and there is fuel everywhere around the carb. it's aprears to bee leaking from some sort of valve lever on the carb. and now its worse. it will start and idle perfect, rev up fine, as soon as i put it into gear and try and go it dies. help!!!!!
my GEUSS is that its the power valve in the carb, should i rebuild it?
casperfast is offline   Reply With Quote Quick reply to this message
Old 04-17-2008, 01:45 AM   #2 (permalink)
acbk8888's Avatar
acbk8888 is on a distinguished road
Smile dies everytime i hit a bump gas!!!!
My SJ410 had an AISIN Carb installed when I bought it. Not sure if its the same for yours. Here's a little past experience I had.
Checked the fuel hose connections and make sure nothing is loose. Use a hose clamp if necessary, its cheap and just to be sure.
Are there any tears around the connecting end of the hose to the carb? Change the hose if required.
Also, there's a "float" inside the carb that controls/limits the flow of fuel into the carb that you might want to check. You might want to check the float/lever to make sure it's working properly or the carb would overflow and thus fuel spilling out all over.
About the Engine dying suddenly, you might want to also check the mini fuel filter inside the carb for impurities/blockage. Mine had similar problem till i had the filter replaced.
Hope this helps.....Good Luck.
acbk8888 is offline   Reply With Quote Quick reply to this message
Old 04-17-2008, 02:13 AM   #3 (permalink)
ok, ill check the lines, im gonna rebuild it anyway. but the internal filter can cause it to die when i hit a hard bump?
Old 04-17-2008, 02:47 AM   #4 (permalink)
acbk8888's Avatar
If the internal filter is clogged, it blocks the fuel from getting into the next chamber where air/fuel gets mixed for burining. In simpler terms, fuel supply to the engine gets suddenly cut off, so, no fuel = engine dead....sorry, not a trained mechanic, don't know the proper part name P
When that happens, you get an overflow where the fuel would spill out from the air intake hose.
Old 04-17-2008, 02:49 AM   #5 (permalink)
ok, so rebuilding the carb will fix all this then right?
Old 04-17-2008, 03:03 AM   #6 (permalink)
acbk8888's Avatar
hehe, maybe we're separated by a comon language...when you say "rebuilding", i assume you mean repair/replacing internal parts right?
in my case, yes, it fixed all the problems. start-up, idle, rev up = ok, fuel spilling all over, engine dying whenever i put into gear.
you might also want to check on your fuel filter, usually located on the hose near the fuel tank. just to make sure it's not clogged up as well. It's a white semi-clear plastic. cheap but important as well. (see photo)
Old 04-17-2008, 03:06 AM   #7 (permalink)
looks like a genaric filter, can i replace it with any fuel filer like that? where is it located?
Old 04-17-2008, 03:29 AM   #8 (permalink)
acbk8888's Avatar
Smile
Get one that is made of clear/white plastic, easy for your to check if it's dirty/clogged and needs replacing. You could check out this link.
eBay Motors: Fuel Filter, 85-88 SUZUKI TRUCK All Models ( 4-1300 1.3 (item 110243470335 end time Apr-19-08 19:53:00 PDT)
It's installed along the fuel hose between your fuel tank and the carb. Usually near the fuel tank, so you may have to get under the chasis to check.
I had mine moved from below the chasis (near fuel tank) and placed under the hood near the carb so I didn't have to crawl under everytime i check.
Old 04-17-2008, 02:49 PM   #9 (permalink)
Ironrat's Avatar
Ironrat is on a distinguished road
Check the gasket where the float is.
Ironrat is offline   Reply With Quote Quick reply to this message
Old 04-17-2008, 02:58 PM   #10 (permalink)
ok, thanks guys, ill be replacing the filter and rebuilding the carb tomorrow
