Replacing the worn out 1.3 with a 1.6 in '87 Samarai? - Suzuki Forums: Suzuki Forum Site
Old 02-15-2017, 09:23 AM   #1 (permalink)
ColoGuy is on a distinguished road
Default Replacing the worn out 1.3 with a 1.6 in '87 Samarai?
I am buying an '87 Samarai rock crawler with a well worn 1.3 that blows oil for a couple minutes after starting. It has a gotpropane kit so a fuel injected 1.3 is not an option.
Running an ad for a good 1.6 for about $300. Have read that it may bolt in and have read that adapters are available.
Hoping somebody has some experience or something with this.
ColoGuy is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 07:05 PM   #2 (permalink)
It doesn't always blow smoke after start up. We think it may be valve seals. Good valve shop in Colorado?
Old 02-19-2017, 07:27 PM   #3 (permalink)
Beuller1 is on a distinguished road
The 1.6 was one of the easiest swaps ive ever done, i also added an isky cam, thorly header, and a weber carb. Only regret is the weber, they are horrible at climbing hills, should have gone harley carb conversion
Sent from my SM-G928P using Tapatalk
Beuller1 is offline   Reply With Quote Quick reply to this message
Old 02-20-2017, 04:26 AM   #4 (permalink)
Guest
You need an adapter and you need to move or replace one engine mount to get the engine in. If you are running standard height then you will need to use the 1.3 oil sump and modify the oil pick up pipe.
Old 02-20-2017, 11:59 AM   #5 (permalink)
Interesting. I have read that the 1.6 exhaust manifold is pretty darned good stock. Apparently my readings about how great webers are did not include climbing. Propane seems great so far. I bought the tube buggy for climbing.
Getting ready to put it through some paces with nice weather. Welded Toyota axles, 38" tires, and 6.5:1 transfer case...have my hopes up.
The challenge so far has been finding a 1.6. Could be the time of year...still winter in Colorado. Do the 1.6s cost much more than the 1.3s?
I have seen 1.3s that "seemed alright" for $300.
Old 02-20-2017, 12:06 PM   #6 (permalink)
Bottom of the oil pan is 32" off the ground. Doesn't seem stock.
Old 02-20-2017, 07:16 PM   #7 (permalink)
Climbed my first hill today. It could use a 1.6 with a few mods. With the 6.5:1 transfer case, it has the power to climb. The problem is getting the 38s started without 4WD reduction.
Rides like a small tank. I'll have to look into improving the ride quality. Probably would involve compromises.
I can unlock the front hubs until the climbing starts.....
Old 02-21-2017, 08:56 AM   #8 (permalink)
Do you recall the 1.6 production years that gave "easy swaps?"
How did you find a 1.6?
Old 06-09-2017, 10:34 AM   #9 (permalink)
Sorry habe not been on in a while my 1.6 was out of a 93 tracker, but an zuke 1.6 should be just as easy
Old 02-10-2018, 07:32 PM   #10 (permalink)
My motor was an 8 valve out of a 93 tracker, 8 valves make it even easier, ive read 16 valves can be a headache to wire.
