New Samurai with a few problems - Suzuki Forums: Suzuki Forum Site
Old 07-06-2016, 07:50 PM   #1 (permalink)
SamuraiNoob is on a distinguished road
Default New Samurai with a few problems
Well, as my username states, I am a Samurai Noob. I don't have a ton of mechanical knowledge but I am learning fast (I'm 18 and my dad is a businessman lol)
I have a few electrical issues and I don't know where to start.
The check engine light doesn't turn on when I have the key on.
The other issue is the turn signal fuse keeps blowing whenever I turn the key on. I have disconnected each front turn signal one at a time to rule out if that was the issue. The hazard lights work so I know it's not the bulb even though the hazard lights are on a different circuit.
Like I said I don't know a lot and would appreciate any ideas.
Thanks!
SamuraiNoob is offline   Reply With Quote Quick reply to this message
Old 07-06-2016, 11:07 PM   #2 (permalink)
ack
ack's Avatar
Thanks!
Did you check the rear turn lamps?
Usually, this problem is related to a loose or broken ground or a poorly rewired aftermarket bumper.
Go to Ack's FAQ and do a search for diagram. Among the results you will find two color versions of the 1988 Samurai diagram created by Cory "Dice" Daniels. Take a look at the first one listed. It is the unmodified version. The other version contains mods that might be of interest to you later in your Samurai adventure.
Use the color coding to make sure the wiring has not been tampered with by the previous owner and that the ground wires at each fixture are properly grounded to the body or frame.
If you have further questions feel free to ask them here!
I hope that this helps!
- Ack
'14 Ford Transit Connect DD
Old 07-07-2016, 02:06 AM   #3 (permalink)
Thanks for the website link! That looks like it will provide a ton of info. I have the diagram pulled up but to be honest I'm not entirely sure what to look for. I have checked the grounds and they seem to be secured to the frame or body just fine. What's really weird is that they were working a few months ago because the previous owner had it pass safety and emissions with no issues. That was after the aftermarket bumper was installed. I can take a more thorough look at everything but like I said I'm not sure exactly what to look for. Thanks again!
Old 07-07-2016, 05:45 PM   #4 (permalink)
I feel stupid for not mentioning this but when I have the key on it makes an electrical whining noise with a few clicking noises then stops. When the noise stops the seatbelt light shuts off too. I think I have something super weird going on.
Old 07-08-2016, 07:06 PM   #5 (permalink)
Did some more digging and now I'm really lost. I found that two of this thing I'm not even sure what to call was not plugged into two of the connectors. A different connector is just dangling with nothing plugged in but only has 3 slots and not 4 like the other two that had that thing plugged in there. I am totally lost now. I put the pictures in the attachments. Any ideas?
Click image for larger version
Old 07-09-2016, 05:58 AM   #6 (permalink)
Darrell.'s Avatar
Assuming yours is a fuel injected model the noise is quite normal (if its not too loud). When the key is turned on the pump will run for a few seconds to pressurise the system.
Don't know about the seatbelt light though.
2005 Grand Vitara MT 1600se.
Old 07-09-2016, 06:03 AM   #7 (permalink)
Darrell.'s Avatar
Attachment 68834
Attachment 68842
The top photo looks like a relay with the cover removed.
I believe yours should have 2, the main relay and a fuel pump relay.
Its not that uncommon to find connectors going nowhere, if you could take a pic showing the wire colours we may be able to tell what it does and if it needs to be connected.
Old 07-09-2016, 06:17 AM   #8 (permalink)
Darrell.'s Avatar
I've just had a look through the USA wiring diagram and see there are 2 other relays, one for the horn and a check relay (whatever that is).
Again the wire colours will identify which is which.
Also what year is it.
Old 07-09-2016, 06:21 AM   #9 (permalink)
Darrell.'s Avatar
Sorry, forgot the welcome..........so
Don't worry about being a noob, for an 18 year old I would consider this a good vehicle to learn with.
Old 07-09-2016, 01:28 PM   #10 (permalink)
I replaced the 2 relays I was talking about. It didn't change a single thing so at least I ruled that out.
It's a 1990 and it is fuel injected. Still have no idea where to go from here
I really appreciate all the help! You guys are awesome!
