Jimny Horn Goes Off When I Turn The Ignition Off - Suzuki Forums: Suzuki Forum Site
Old 12-17-2015, 03:17 AM   #1 (permalink)
BluShark482 is on a distinguished road
Question Jimny Horn Goes Off When I Turn The Ignition Off
So this is my first post on the forum and i would will your help on a troubling matter.
I own for two years now a Suzuki Jimny JB33 Soft Top and I recently had my clock spring broken so i disassembled the steering column and repaired it. It was an easy thing to fix. I had to reweld the end of the tape inside the housing of the clock spring and the horn and the airbag instantly came to life after I reassembled the steering column.
The problem that has surfaced now is that when i turn the key to the OFF position and remove it from the column in just a few second the horn starts blowing and won't stop. When i reinsert the key in the ignition and turn it to either the ACC or ON position the horn stops the continues blowing and start to operate and behave like a normal horn and blows only when the horn buttons are pressed. And again after i turn the key to the OFF position the same thing happens. After a few seconds the horns starts its crazy blowing and won't stop until the key is reinserted and turned.
So for now to be able to drive my car i have disconnected the cable going into the steering wheel horn buttons. With this cable disconnected the horn doesn't blow when i remove the key but it also doesn't recognize when i press the buttons on the wheel.
I can't find what might be wrong with it. Everything was operating properly up until the time (2 weeks ago) that the clock spring got damaged and now that i fixed it the horn is going crazy on me....
Thanks in advance for any info that you can give me.
BluShark482 is offline   Reply With Quote Quick reply to this message
