Hook battery charge backwards no power in cab - Suzuki Forums: Suzuki Forum Site
Old 10-18-2015, 10:35 AM   #1 (permalink)
ghs6287@aol.com is on a distinguished road
Default Hook battery charge backwards no power in cab
I hook the battery charger backwards.. The smoke came out around the battery. Now I have no power to ignition or lights. I check the power at the starter and I have 12 volts. But none at the dash or lights work. What do you think it is or what do I do.
ghs6287@aol.com is offline   Reply With Quote Quick reply to this message
Old 10-18-2015, 11:06 AM   #2 (permalink)
You need to closely inspect for blown fuses and melted wiring to start with.
You may have toasted the battery to the point of no return as well.
Old 10-18-2015, 12:41 PM   #3 (permalink)
Darrell.'s Avatar
Hopefully the smoke was nothing more than the fuselink melting. This is the main wiring protection. I don't know if they are still readily available.
Edit- Just re-read my reply and this only applies to the SJ-Samurai, the Jimny (in the UK anyway) would have a regular fuse.
2005 Grand Vitara MT 1600se.
Old 10-18-2015, 12:51 PM   #4 (permalink)
I check all fuses And wires no sign of blown fuses or burnt wires. Battery still has 12 volts.
Tha wire is in the picture will that cause it to not to have power to anything. Also I hook the battery charger to the battery cables on start mold and still had no power to anything.
Thanks for the help.
This is a samurai !
Old 10-18-2015, 12:59 PM   #5 (permalink)
Darrell.'s Avatar
Yep that wire supplies all the power other than the large supply to the starter.
It may not look totally burnt out.
Here is a link to a post I did on another forum with more info.
You may just want to get a multimeter on it.
Suzuki Club UK ? View topic - Fuselink info
Old 10-18-2015, 01:34 PM   #6 (permalink)
Its was that wire !!! Thank you so much for the help !!!!
Old 10-18-2015, 02:55 PM   #7 (permalink)
Darrell.'s Avatar
This is about the only place other than a Suzuki dealer that stocks them.
Classic car dealers may well keep just the wire in stock.
Suzuki Samurai Battery Fusible Link (To Main Fuse Assembly)
Old 11-19-2015, 08:00 PM   #8 (permalink)
PoppaSmurff is on a distinguished road
NAPA also carry's that fusable link you just need to know what guage it is to replace it.
PoppaSmurff is offline   Reply With Quote Quick reply to this message
Old 09-05-2016, 11:43 AM   #9 (permalink)
moon2012 is on a distinguished road
so i know this thread is a little dated but i am having similar issues.
NO lights no sounds in the cab and on top of that i am blowing the ignition fuse. replaced with a 30 amp fuse for a short time and got some lights and then it blew too
from everything posted on here and what i read about the fusible link, sounds like i don't have one.
someone has wired in a larger diameter wire from the battery to the alternator and white /yellow striped wire with a wire nut...
I do not have the fusible link coming from the battery i have the female connection but not the male from the battery.
my question is if the fusible link wasnt used and that large diameter wire was bypassing something what would be damaged to create a short or ground somewhere. the white and yellow wire what does that power or run to.
please someone tell me its an easy ignition switch or something to replace instead of chasing all the wires looking for it to melt through somewhere.
also i have alot of disconnected wires due to having a weber carb on it not the original so not sure if anything else that either goes to or comes from the ecu is needed or could be causing some issuseS? it ran fine as it was untill the battery fell over and both positive and negative cables came off the battery.
please help.
moon2012 is offline   Reply With Quote Quick reply to this message
