87 Samurai Mechanical pump issue - Suzuki Forums: Suzuki Forum Site
Old 06-27-2015, 05:55 PM   #1 (permalink)
smbearkat90 is on a distinguished road
Question 87 Samurai Mechanical pump issue
My 87 Samurai is not running good. I have to keep pumping the gas pedal to get it running like it supposed to. I Took the mechanical pump off, cleaned and re-apply the gasket. Applied light oil on rod(according to Haynes manual book). Also replaced fuel filter as well.
Stupid question: does the 87 samurai have electric pump inside the tank which book said fuel injected vehicles. Engine run idle fine..it's when I start driving, sometime got it going sometime feels like not getting gas to run it.
What's your suggestion to troubleshoot. I hate to drop the gas tank if that thing has electric pump.
smbearkat90 is offline   Reply With Quote Quick reply to this message
Old 06-27-2015, 08:48 PM   #2 (permalink)
Azelgin's Avatar
No electric pump in the fuel tank, on carbureted Samurai.
Did you change the fuel filter on the rear frame, by the gas tank? I see many Samurai where people have added a filter under the hood, by the carburetor. The next owner sees this filter, changes it and still has a plugged filter problem, not realizing the problem is stemming from the standard filter located on the frame.
Old 06-30-2015, 04:55 AM   #3 (permalink)
I put a new aluminum type filter. Do I need get specific filter for it?
Old 06-30-2015, 04:57 AM   #4 (permalink)
Filter is located on rear passenger side along the frame. Is there another one I missed?
Old 07-28-2015, 04:44 PM   #5 (permalink)
Brown29 is on a distinguished road
No, unless it was added by a previous owner.
Brown29 is offline   Reply With Quote Quick reply to this message
Old 08-15-2015, 01:22 PM   #6 (permalink)
Default Fuel tank
Dropped tank down. No filter nor electric pump. Still having problem get motor running. Sometime it run fine and when motor make it sound like I am running out of gas. I have to stop and pump gas until it idle normal. Next troubleshoot is to replace fuel pump. Found reasonable price from RockAuto.com
Old 08-21-2015, 09:55 PM   #7 (permalink)
Could be a bad carburetor... but if the diaphragm on your fuel pump is ruptured it may not pump enough under load. Notice any leaks from the tube that points down on the fuel pump? Duct tape a plastic water bottle to it and see if it fills with gas (or oil depending on which side the leak comes from). I have seen them leak oil like a sieve there before, but they can also leak gas.
Old 09-03-2015, 08:12 PM   #8 (permalink)
Default Carb
Installed new Fuel pump..it works then decided to rebuild carb (gaskets, water choke gasket, power valve and float needle). I cranked several times and can't get it running. Gas not going in carb. Sprayed starting fluid and engine does turn over shortly. Am I supposed to prime the gas line?
Old 09-05-2015, 03:50 AM   #9 (permalink)
Guest
I had to prime my new pump.
