Engine revs up and down after warmup, 90 samurai - Suzuki Forums: Suzuki Forum Site
Old 01-27-2007, 02:47 PM   #1 (permalink)
RebuildIt is on a distinguished road
Default Engine revs up and down after warmup, 90 samurai
I would appreciate some insight on this problem.
Whenever i start it up, it runs smooth until the engine reaches
its operating temperature, then the idle starts whining up and down.
It seams to stop after i hit the gas pedal, but then it comes back a minute or so later..
Does anyone have any idea on how to fix this..?
RebuildIt is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 01:45 AM   #2 (permalink)
Pommy is on a distinguished road
Default Up and Down...
Hi,
What happens if you floor it for a second (out of gear!) ?
Does it struggle, pause, or rev up normally?
If normally, I would suggest the cause may be the idle solenoid.
(Get one from a wreckers if you can due to OEM being expensive)
If not, I would clean the carb in one of two ways -
1. Buy a spray from your local automotive shop CARB-I-CLEAN or something like that - it just sprays in with the engine running.
2. Take the carb off and do it the harder, but proper way (still using the spray)
Cheers,
Pommy.
Pommy is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 08:30 PM   #3 (permalink)
Default Revs
If i floor the gas, the revups seem to be consistant (no hesitation).
Its only when it idles.
But It statred doing that after I have swaped in a the exhaust from a swift, (same motor) and i put in a new O2 sensor. To me that should make no difference at all to the way the car idles.
I will try to spray some carb cleaner into ot and see if that will take care of the problem, if not i will try to change the idle solenid..
Thanks Pommy.
