1.3L rebuild engine - Suzuki Forums: Suzuki Forum Site
Old 03-28-2015, 06:27 PM   #1 (permalink)
jloza is on a distinguished road
Default 1.3L rebuild engine
Iam planning on rebuilding my 1.3 in my sammie and was wondering if anybody knows what size hone Iam going to need also any tips on how to rebuild this 1.3L sure would be apprecitaed
thanks
jerry
jloza is offline   Reply With Quote Quick reply to this message
Old 03-29-2015, 12:41 PM   #2 (permalink)
I cant answer the hone size question sorry
But get the field service manual and the other is make sure you lap the head and the block properly. Why the lapping effort...that what my mechanic did and I lost all my water twice due to hose failures and did not blow the head gasket.
Other than that get OEM components if you can...good luck
Common Sense is not that common.
Old 03-29-2015, 02:46 PM   #3 (permalink)
what do you mean lap the head and the block ?
Old 03-29-2015, 07:35 PM   #4 (permalink)
I think I replied to your question in another forum - I'll summarize that here - from the questions you're asking, you seem to lack the experience required to tackle this project on your own.
These engines are simple and not difficult to rebuild, but if you lack experience, it's highly recommended that you find someone who can look over your shoulder and guide you through the steps involved in the rebuild.
The size hone will be dictated by the size bore (and that information is in my other reply), whether of not you need to hone will be determined by what you find when you tear down the engine and measure the wear.
As for lapping the head & block - you're basically ensuring the mating surfaces are flat & square so they will seal properly - I'm also going to point out that lapping the head/block may not even be required - what IS required is that you check it with a straight edge & feeler gauge to determine if it needs to be done.
Old 03-29-2015, 08:09 PM   #5 (permalink)
thanks for the reply ive torn the engine down and the cylinders look good no scratches or wear they look really good
Old 03-30-2015, 07:08 AM   #6 (permalink)
You can do an "eye-ball" assessment if you want - it's your engine - but - if you can detect wear and "out of roundness" with the naked eye, then you don't need my advice, and you probably wouldn't be asking what size hone to use.
You have to know your limitations, I can only guess, based on the questions you ask.
FWIW - the last G13 I pulled down had no wear ridge at the top of the bores and even had factory knurling visible on the pistons - when miked it was within acceptable tolerance, but just barely, the machine shop suggested honing & new rings, but when honed, it was outside the limit - I bored it oversize.
Bottom line - it's YOUR engine.
Old 03-31-2015, 06:59 PM   #7 (permalink)
A look see is good but using inside micrometer would be better.
I am also assuming you got a copy of the FSM as I suggested.
Old 03-31-2015, 07:02 PM   #8 (permalink)
ok thank the block and cylinders look good ill probably still hone it just to be sure
jerry
