SJ413 refuses to idle - Suzuki Forums: Suzuki Forum Site
Old 08-24-2006, 03:11 AM   #1 (permalink)
Sketco is on a distinguished road
Default SJ413 refuses to idle
I have a Suzuki Sierra '93 SJ413. I inadvertantly poured 2 litres of 2 stroke (40:1) fuel into the tank about 2 months ago. I wouldn't have thought that this puny amount would make a difference, and indeed after some rough idles for a while, it cleared. Now the vehicle refuses to idle, but performance is subjectively unchanged otherwise.
I used a bottle of Wynns spitfire carby cleaner in the tank just in case, and have cleaned the internals of the carby with a proprietry (alcohol I guess) based spray. Checking the timing is obviously problematic, but I can't imagine this would have changed dramatically in a few months. There is no missing, or (as far as my ears can tell) hunting.
Do the forum members think this is fuel/carby related or something else by coincidence..I'm out of ideas right now.
Cheers
Mal
Sketco is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 12:45 PM   #2 (permalink)
rohanday is on a distinguished road
the oil can split and so sit at the bottom of your tank i,d recomend a tank drain and then take the carb off and give it a good clean ,i fitted a leaver under the stearing column attached to the throttle so i can ajust the idle as i need eg if it wont tick over and i,m goin down steep rocky shit i make it idle at 2500 and just use the clutch and brake
be fast be dirty, or just be dirty fast
rohanday is offline   Reply With Quote Quick reply to this message
Old 01-26-2007, 06:01 PM   #3 (permalink)
Appreciate the reply. I was afraid I might have to go through the whole tank removal/ drain thing. I've never drained and cleaned out a tank. I would assume you don't use water for flushing. Is there an effective method you are aware of?
Cheers
Mal
Old 01-27-2007, 05:57 AM   #4 (permalink)
just flush with a bit of clean petrol then drain it take off all filters from fuel line, i,ve seen as many as 3 used befor blow out the lines with an air line if available , appart from all this it could be a carb problem i had to take the cold starter bit off my carb so my car now dosnt have a choke but it does idle properly when its warm now
Old 01-27-2007, 05:02 PM   #5 (permalink)
Ok, looks like my Sunday activities are taken care of ..thanks, much appreciated.
