Speedometer - Suzuki Forums: Suzuki Forum Site
Old 01-15-2015, 09:53 PM   #1 (permalink)
ammoduc is on a distinguished road
Default Speedometer
I'm driving 60mph on freeway..speedometer is saying 95mph(I wish). What is the problem? The speedo cable or the actual speedometer?.
ammoduc is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 10:43 PM   #2 (permalink)
graphicjunkie's Avatar
graphicjunkie is on a distinguished road
Garage
Need more details.
If it had (way) bigger tires, and had the speedo recalibrated for it, then putting normal size tires on it again will do that...although, that seems like pretty drastic numbers.
WillyB
88' - 29's - Myside2
graphicjunkie is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 11:09 PM   #3 (permalink)
1988 Hardtop 1.3 Engine 68k Original miles. As stock as humanly possible.
Old 01-26-2015, 09:11 PM   #4 (permalink)
digidoggie18 is on a distinguished road
Have you been back behind the instrument cluster at all lately? The speedometers are adjustable in the back of them
digidoggie18 is offline   Reply With Quote Quick reply to this message
Old 01-26-2015, 09:38 PM   #5 (permalink)
WHAT? Adjustable?? I was there saturday and it all looked good. I added some oil drops into the speedometer holes. I also noticed that the cable had a zip tie holding the air tube and the cable together so I removed it. I then took it for a spin and NOTHING same old 30mph when I'm only doing 20mph. Can you tell me how to adjust it? I'm currently using the GPS as my Speedometer.
Old 01-30-2015, 07:46 PM   #6 (permalink)
jamesmcmillen8's Avatar
jamesmcmillen8 is on a distinguished road
i have been having the same issue with mine. I did do the led conversion on mine though but it says im going 10 mph slower that what i actually am, i have been trying to see how to adjust it but have had no luck. Any suggestions?
jamesmcmillen8 is offline   Reply With Quote Quick reply to this message
Old 01-31-2015, 08:43 AM   #7 (permalink)
Guest
https://www.suzuki-forums.com/suzuki-...eedometer.html
Old 01-31-2015, 10:04 AM   #8 (permalink)
One word: THANK YOU.
Ok that was two.
Old 01-31-2015, 08:09 PM   #9 (permalink)
Sorry about that I wasn't on this site but yes pretty much all speedo's are adjustable electronically or digitally. Perfect article that rhinoman put up.
Old 02-03-2015, 10:11 AM   #10 (permalink)
ack
ack's Avatar
It is important to know that the adjustment described at Zuksoffroad is mechanical and only affects the speedometer readout. The adjustment is there specifically for situations where, for some internal-to-the-dash-panel mechanical reason, your speedometer becomes uncalibrated. this would include mishandling or bumping the unit while it is out of the dashboard.
If you make this adjustment to correct your speed on a vehicle with non-stock gearing or tire sizes, the Odometer readings - which are ONLY affected by changes in the drivetrain gearing/tire size - will NOT be correct!
To paraphrase a common advertising statement:
YOUR MILEAGE WILL VARY!
I hope that this helps!
- Ack
Ack's FAQ
'14 Ford Transit Connect DD
