Blue smoke from exhaust! - Suzuki Forums: Suzuki Forum Site
Old 01-07-2015, 03:10 PM   #1 (permalink)
Chris Stoffel's Avatar
Chris Stoffel is on a distinguished road
Default Blue smoke from exhaust!
I need some advice! I have a 93 Samurai(South Africa) with the factory carb. When I go downhill, with my foot of the gas but still in gear and when I give some gas a cloud of blue smoke comes out the exhaust. This also happens when I want to loose some speed and after about 100 feet of freewheeling in gear and then excelarate the cloud of blue smoke comes out the exhaust. I've had the Sammy for about two weeks now and everythings seems fine. It has 65000 miles on the clock.
Chris Stoffel is offline   Reply With Quote Quick reply to this message
Old 01-07-2015, 03:25 PM   #2 (permalink)
That is typical oil burning, past pistons and rings.
Old 01-08-2015, 10:16 AM   #3 (permalink)
caseyjones955's Avatar
Oil smoke does not dissipate quickly and has a distinctive smell. If it comes in intermittent puffs could it be valve seals? I'm not well versed on the 1.3 so don't know if this is an issue but without tons of miles is this a possibility? I have had other engines do just this with only failed valve seals.
Old 01-08-2015, 10:58 AM   #4 (permalink)
The key to this one is the...
When I go downhill, with my foot off the gas but still in gear
Classic high intake vacuum scenario, pulling oil up past the rings.
Not to say that the engine isn't simply tired AND suffering from excessive valve stem to guide / seal wear as well.
A compression test would be prudent here.
Old 01-08-2015, 12:15 PM   #5 (permalink)
Default Chris
Thank you for the replies! I think I will have a compression test done! It is of course possible that the sammi's speedo have turned over more than once. The speedo reads 8800km and I was told it has turned over once, making it 108800km's. But it pulls well and I am not yet worried about the condition of the motor. I've only had it for two weeks and I need to learn a lot more about the Samurai!
Old 01-14-2015, 04:46 PM   #6 (permalink)
Sandboarder's Avatar
Sandboarder is on a distinguished road
Garage
Chris, I live close to you in Welgelegen Northern Surburbs. Come by my place if you want me to check it out
Is the engine a G13BA or G13A?
Sandboarder is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 09:39 AM   #7 (permalink)
Hi Sandboarder
Thanks for the offer, I will keep it in mind. It is the 1298cc engine. I am not really worried about it anymore, some cars do smoke on downhill, BMW's is known for that. I will be doing a compression test soon, just so that I know. The 31st Jan I am going to test the Sammy at Helderberg 4x4 trail. Not the most difficult trail but at least a playground!
Keep well
Chris
Old 01-16-2015, 04:27 AM   #8 (permalink)
Garage
That is the G13BA engine then, exactly the same as mine.
Keep a good eye on the oil level. I had the exact same symptoms on 105kkm and turned out to be a broken piston skirt. In my research I've found numerous cases of this happening to the G13BA's
Pull the spark plugs and check if they are either all covered in oil or only 1.
A compression test was useless in my case as only the oil ring broke and the compression rings remained intact. This resulting in a perfect compression figure on all 4 cylinders.
97' Samurai Coily
Old 01-16-2015, 03:25 PM   #9 (permalink)
Sandboarder, Baie dankie! I appreciate your advice! I will look at the plugs first and keep an eye on the oil and report back.
Chris
Old 01-19-2015, 09:56 AM   #10 (permalink)
Hi Sandboarder. I pulled the plugs and they seem OK. No traces of oil and they are a light grey color. Is this good? I am checking the oil but no difference yet.
