jimny coolant loss - Suzuki Forums: Suzuki Forum Site
Old 08-07-2006, 05:09 AM   #1 (permalink)
gavv8 is on a distinguished road
Default jimny coolant loss
My mother has a '51' reg jimny with approx 35000 miles on the clock, it is used very lightly with mostly local stop start driving.
The only problem with it is that it uses approx 2 litres of coolant a week, it runs fine, has no coolant in oil or vice versa and both the the temp gauge and heater operate as per normal with the temp gauge staying within the normal range even when very hot weather.
I can't see any obvious leaks and there doesn't seem to be any obvious staining anywhere in the engine bay.
Any help would be very helpful.
G.Cook
gavv8 is offline   Reply With Quote Quick reply to this message
Old 08-25-2006, 10:56 PM   #2 (permalink)
suzukifreak is on a distinguished road
sometimes the tube that runs along the side of the engine (in between the hoses from lower radiator) develops a pin-hole leak which under pressure leaks and will run along various paths on engine etc, so it is hard to detect because of evaporation. Hope that helps.
suzukifreak is offline   Reply With Quote Quick reply to this message
Old 08-26-2006, 07:56 AM   #3 (permalink)
Many thanks, i will investigate .
Regards
gavin
Old 09-03-2006, 12:18 PM   #4 (permalink)
CoolHands is on a distinguished road
Use a pressure tester to check that - or it would be cheap for a local garage to check using one if you haven't got one. Otherwise it could be the head-gasket, especially if its 2 litres a week. Thats a lot.
Do you appear to be getting steam out the exhaust? Cos it could be going straight into a cylinder and get burnt, which is why you don't always get oil contamination.
CoolHands is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 10:41 PM   #5 (permalink)
Joaobaeta's Avatar
Joaobaeta is on a distinguished road
People!
Stranger.... He never happened with my Jimny.... Mine it is year 2001 and it is with 65200km or 40750 miles.
Joaobaeta is offline   Reply With Quote Quick reply to this message
Old 10-01-2006, 10:14 PM   #6 (permalink)
Tin Can's Avatar
Tin Can is on a distinguished road
Originally Posted by Joaobaeta
People!
if there is alot of smoke when you warm up the car in the morning and i mean alot that means that your heads are gone cos my Sierra done the same thing alot of smoke was blowing out then i found out my haeds blue and my engine seized
Tin Can is offline   Reply With Quote Quick reply to this message
Old 10-01-2006, 11:19 PM   #7 (permalink)
Joaobaeta's Avatar
People,
Stranger...... So can be the catalyser that must be with problem?
