#3 cylinder misfire - Suzuki Forums: Suzuki Forum Site
Old 09-08-2014, 10:11 PM   #1 (permalink)
mikepo is on a distinguished road
Default #3 cylinder misfire
I have an 87 Samurai 1.3 and the #3 cylinder is dead. Checked the plug, wire, distributor & cap. Everythings fine.
Has anyone had an issue with the EGR sending exhaust gas to the #3 and killing the fire?
Thanks.
mikepo is offline   Reply With Quote Quick reply to this message
Old 09-09-2014, 05:52 PM   #2 (permalink)
aicomp's Avatar
aicomp is on a distinguished road
Has it got compression? Mine did that when a valve stuck open.
1986 Samurai, 31X10.5 tires, OD paint, Complete cage, 12000 lb winch, custom homebrew front and rear bumpers, 4.59 transfercase gears, 3" springover, custom homebrew shackles, all new bushings, brakes, Harley 44 carb conversion.
aicomp is offline   Reply With Quote Quick reply to this message
Old 09-09-2014, 10:10 PM   #3 (permalink)
160+ dry & 170+ wet on all cylinders
did a vacuum check last night. Nothing out of the ordinary
going to do a spark check just to eliminate spark from the equation.
changed #2 & #3 plugs & wires already. didn't help.
It's not following all the logical rules for a dead cylinder.
Thanks for the help
Old 09-09-2014, 11:26 PM   #4 (permalink)
aicomp's Avatar
Any carbon tracks or cracks in the distributor?
Mike
Old 09-14-2014, 11:29 PM   #5 (permalink)
replaced cap & rotor
bought spark tester.
all 4 cylinders sparking fine
removed intake and found big piece of gasket missing on #3 cylinder (see pic)
I'm hoping this was the problem.
Old 09-15-2014, 07:30 PM   #6 (permalink)
texas 87sami is on a distinguished road
That would cause the cylinder to run lean, so hopefully that will cure your problem.
88 soft top rescued from the junkyard. Mods: Harley carb & homemade intake adapter, 4.16 gears and a Twisted TT shifter in the transfer case, RMS mini spool in the rearend, CJ/RUF SPUA, 235/75/R15 tires and 2 tone rattle can paint.
texas 87sami is offline   Reply With Quote Quick reply to this message
Old 09-27-2014, 10:25 PM   #7 (permalink)
Got the intake gasket replaced. Added a new Weber carb. Runs like a top now.
Old 09-27-2014, 10:29 PM   #8 (permalink)
Do they make weber's that small?
2008 Swift M15A
Old 09-27-2014, 10:36 PM   #9 (permalink)
Yes. It's a 32/36 downdraft. Has all the adaptors. bolted right up using the stock air cleaner.
Old 09-27-2014, 10:56 PM   #10 (permalink)
let me know how it behaves, I know someone who is looking at a carb swap, do you know what jets you have in it?
I'm a 4 barrel junkie, not so hot on the 2 barrel babies.
2008 Swift M15A
