Sami second gear - Suzuki Forums: Suzuki Forum Site
Old 06-26-2014, 12:39 PM   #1 (permalink)
aicomp's Avatar
aicomp is on a distinguished road
Default Sami second gear
Hi All,
I have a 1986 Samurai and it jumps out of second gear when coasting. Stays in gear when pulling. Only happens in second. Any ideas?
Thanks,
Mike
aicomp is offline   Reply With Quote Quick reply to this message
Old 06-28-2014, 11:04 AM   #2 (permalink)
caseyjones955's Avatar
Assuming you have been through the normal checks like anything interfering with shifter, motor mounts, fluid level etc, I would venture to say synchro or bearing.
Old 06-29-2014, 11:14 AM   #3 (permalink)
aicomp's Avatar
Thanks for the reply. I had rebuilt the trans with a complete bearing and syncro kit from Lowrange Offroad. I fear that I may have gotten a syncro in wrong. I noticed thet it also does not go into fourth gear without grinding a little unless you hesitate between shifts. I am going to drive it for now and maybe just go through my other trans and try to do a better job.
Mike
Old 06-29-2014, 11:22 AM   #4 (permalink)
Did you replace the shift sheet (cute little bronze or nylon collar directly under the shifter)?I dont mean to sound like a dickhole but it would be easy to miss
Exactly what fluid did you use to fill?
I recently rebuilt my trans as well and went through some different fluids with notably different results.
Old 06-29-2014, 11:39 AM   #5 (permalink)
aicomp's Avatar
Hi,
Yes, I replaced the shift sheet. I am using a 75w 140 synthetic fluid. I was thinking also that I might need to change that. What do you use Casey ?
Also, I don't take anything you say as being a dickhole, I am happy to have the input and help.
Thanks again,
Mike
1986 Samurai, 31X10.5 tires, OD paint, Complete cage, 12000 lb winch, custom homebrew front and rear bumpers, 4.59 transfercase gears, 3" springover, custom homebrew shackles, all new bushings, brakes, Harley 44 carb conversion.
Old 06-29-2014, 12:03 PM   #6 (permalink)
Mike
I started out with the Amsoil Synthetic GL4 and it was fussy shifting. I left that in for a while as it was spendy so I decided to allow a few miles for the trans to break-in. Of course nothing changed so I drained it out after maybe a couple thousand miles and went with standard GL5 gear oil recomended for manual transmissions. I put on a couple hundred miles and it was an improvement but still less than what I would expect from a fresh gearbox.
I ended up doing a bit of reading and talking with others and was reminded that standard GL4 (not GL5) was a great thing. I looked all over and found only at Ford but some guys are still finding it at NAPA. Using that now for the last 300 miles and its considerably better, I get 3 and 5 so much smoother now. My trans is shifting now as I believe it should except for the high rpm 2nd gear upshift requires a delicate touch or to wait for the driveline to unload, in any event that seems to have been getting better over the last few miles.
Here is a copy of the thread on the Sidekick board that brought this trans fluid discussion on. Also the specific information including part numbers on the straight up non-synth GL4 gear oil.
I never experienced mine popping out of gear, when you decelerate is there vibration? How were the shift forks when you had the trans apart? I think it might be hard to get a synchro wrong, I know I'm reaching here but maybe a lubrication issue is keeping it from engaging fully...
https://www.suzuki-forums.com/suzuki-...t-problem.html
I will be interested to know how you proceed and what the results are.
Old 06-29-2014, 12:27 PM   #7 (permalink)
aicomp's Avatar
Mike
Hi,
I will try GL4 when I get the Sami back. My Daughter and Son in Law are using it for a week behind their motorhome. You Knoe, I was worried about the shift forks also. I may try to find a set and also a new shift lever. I may also tig weld and shape the shift lever end a little. When I build the other trans, I will get new forks and the whole mess.
I will read the thread that you sent and find out about GL4. I truly appreciate the help and I will update as I go along.
Mike
Old 07-02-2014, 07:48 PM   #8 (permalink)
paz3928's Avatar
paz3928 is on a distinguished road
Garage
Thank you for sharing.....the GL4 is good
1986 Samurai [SOLD]
2004 Jimny [auto, 1300cc VVT, stock]
1981 Jimny with Sidekick 1600cc 8v engine [see pic]
paz3928 is offline   Reply With Quote Quick reply to this message
