Spun Timing belt!? Help! - Suzuki Forums: Suzuki Forum Site
Old 06-06-2014, 08:51 PM   #1 (permalink)
ponythunder is on a distinguished road
Default Spun Timing belt!? Help!
So my 1.3 carb Sammy died going down te highway. I couldn't get fire so I checked to see if the cam shaft was turning when I started it. No go. Spun timing belt. I'm wondering if this is an interference motor? I had literally (15min prior) put all new valves and rebuilt head on it. I hope my valve
Job isn't shot. Also. It looks like part of the cam wasn't getting oil. The love right above cylinder 2 exhaust. Idk if I am going to need new pistons and valves. Or a new cam or what. Please help.
ponythunder is offline   Reply With Quote Quick reply to this message
Old 06-06-2014, 10:14 PM   #2 (permalink)
zooki4x4's Avatar
It's a non-interference motor.
Old 06-07-2014, 07:43 AM   #3 (permalink)
Sounds like you may have flipped the head gasket whilst installing it - a very easy mistake to make - it blocks the oil way leading to the cam bearings - cam seizes for lack of lube and then the belt either snaps or strips the teeth off.
You may need a new head & cam.
Old 06-07-2014, 07:57 AM   #4 (permalink)
Sweet thanks! I figured that out and bought a timing belt. Hopefully it will crank right up!
Old 06-07-2014, 08:10 AM   #5 (permalink)
I went ahead and got a water pump too. It was only $25 so I figured why not. I'd rather it not go out on me. Is a new water pump at 130000 miles a good idea?
Old 06-07-2014, 09:06 AM   #6 (permalink)
Would the cam still turn if I seized it?
Old 06-07-2014, 09:17 AM   #7 (permalink)
Also. The tensioner spring had come off and was wrapped around the crank pulley. Would that have caused the pulley to go ad instead?
Old 06-07-2014, 11:37 AM   #8 (permalink)
No - but the reported lack of oil does not bode well for the future.
Old 06-07-2014, 11:41 AM   #9 (permalink)
That by itself can probably cause the timing belt to jump teeth - what condition was the belt in when you removed it - was it broken? were there missing and/or damaged teeth?
Old 06-08-2014, 02:28 PM   #10 (permalink)
It was a brand new belt. So I noticed that the timing mark I had didn't line up correctly with the mark I had on the dizzy so I thought maybe the cam timing pulley spun. I pulled it of and the attached photos show what it looked like. Why would that happen? I'm guessing a frozen cam would right? But would I still be able to turn the cam by hand?
