Samurai G13A engine rebuild info - Suzuki Forums: Suzuki Forum Site
Old 05-14-2014, 12:26 PM   #1 (permalink)
Sandboarder's Avatar
Sandboarder is on a distinguished road
Garage
Default Samurai G13A engine rebuild info
Hi from sunny South Africa!
I've recently joined as I need some info on my Samurai build
Which way does the crank bolt turn to loosen it?
Counter clockwise or Clockwise?
As for the rocker arm shaft securing screws, they seems to be stuck and I've already broken 2 phillips bits trying to loosen them, any advice here?
Sandboarder is offline   Reply With Quote Quick reply to this message
Old 05-14-2014, 01:40 PM   #2 (permalink)
VaderSS's Avatar
Garage
Counter-clockwise to loosen.
Are you using a hammer-driven impact driver, like this one?
Wayne Bengston
Old 05-14-2014, 03:51 PM   #3 (permalink)
Garage
Thanks Wayne it finally budged.
Nope, I used a breaker bar
When I removed the main end bolts some fluid squirted out, smelling like diff oil or ATF
Old 07-07-2014, 04:03 PM   #4 (permalink)
Garage
I am documenting my rebuild on a local forum, I'll post the whole thing in a while.
I have received my new flat top pistons with new rings but the 2nd compression ring seems to have a small step. Something tells me the step should be installed facing up or am I wrong?
Old 07-07-2014, 06:20 PM   #5 (permalink)
VaderSS's Avatar
Garage
Depends on the ring;
Piston Ring Types
Wayne Bengston
Old 07-14-2014, 06:16 PM   #6 (permalink)
Garage
Piston Ring Types
Thanks I meant to say facing down.
My engine is back together and did the start up tonight.
Every time the engine has to start up it doesn't take first swing (hot or cold) like it used to so the carb should not be the issue here since it hasn't been touched.
It sputters for 5sec and then idles and revs perfectly. What could cause this problem?
As for the ignition timing. I've set it at 10 BTDC for now. What would the recommended ignition timing be for using the high compression pistons 9.5:1 and 95 octane fuel
Old 07-15-2014, 06:19 PM   #7 (permalink)
Garage
Anyone else also running high comp pistons?
