High Compression Pistons?? What Bearings?! - Suzuki Forums: Suzuki Forum Site
Old 01-22-2014, 11:01 AM   #1 (permalink)
samuraijack is on a distinguished road
Garage
Default High Compression Pistons?? What Bearings?!
I recieved an extra engine and transmission when I bought my '86 Sammy, and he said that it had a knock, So I removed the oil pan and felt the rods and noticed that they had some slack (the bearings are done for) What are those bearings? are they rod bearings? main Bearings? I don't want to order the wrong thing!
Also, All the engines he has given me (about 4 with trans) had Hi Compression Pistons, is there a way to tell if this one has high compression pistons without taking them out?
samuraijack is offline   Reply With Quote Quick reply to this message
Old 01-22-2014, 12:12 PM   #2 (permalink)
You are entering a world of exacting measurements and precise parts needs, best left to a competent machine shop.
For instance...you need to determine if the crank is in spec and if turned, what oversize (or standard) connecting rod bearings to purchase.
And that is just the tip of the iceberg as far as the technical expertise required here.
Old 01-22-2014, 12:33 PM   #3 (permalink)
Garage
what do you mean? I did take the bearings off another block i had laying around (for same sammy) and the bearings off that one were too big for the crank i need.
Old 01-22-2014, 01:11 PM   #4 (permalink)
That's my point. One doesn't take bearings from one engine (unmatched / unmeasured) and simply swap them to another crank configuration.
You have to have the tools and expertise to evaluate and measure the fit needs.
Again...technical stuff here. This forum and its members don't have the time nor capability to guide you through all of the steps, nor do you have the tools. It takes on-site training, book learning, assistance from a knowledgeable friend or outside shop services to perform these exacting engine related repair tasks.
If you don't take my advice, you are doomed for failure from the get-go.
Old 01-22-2014, 01:49 PM   #5 (permalink)
Garage
damn, okay haha well time for the engine to go to the shop!!
