No check engine light and scanner shows P0010 - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 07-22-2019, 05:30 PM   #11 (permalink)
aquanaut20's Avatar
For a valid inspection, the CEL must illuminate with key on and extinguish at engine run (if no emission faults), not associated with safety...
However it is your dime, how you handle it is yours alone..
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 07-22-2019, 07:02 PM   #12 (permalink)
Originally Posted by 2000IGNIS View Post
Dealer can say "That's the way it was traded!" as a defense - is there proof otherwise?
Inspector can defend "no fault light visible" as taking reasonable step during an inspection, and is an engine fault light a safety critical item if the engine is running fine at the time?
no they can't, CEL is a mandatory requirement for a safety and emissions inspection there. Same as an ABS light.
Even in the UK they are mandatory for an MOT.
2008 Swift M15A
Old 07-22-2019, 07:52 PM   #13 (permalink)
PatteRC85 is on a distinguished road
I couldn't sleep, so i went out and took the cluster out. Easy job!
But I will never get a "CEL" as the little LED was loose and fell of trying to wiggle it in place. Either i Will get a New cluster or I will re-solder the little LED.
The pointer for the RPM, can it be pulled out? Anyone tried that?
PatteRC85 is offline   Reply With Quote Quick reply to this message
Old 07-22-2019, 08:46 PM   #14 (permalink)
aquanaut20's Avatar
Now you have interfered and destroyed the evidence..
.... Philip
.... Philip
Old 07-23-2019, 07:10 AM   #15 (permalink)
Gallery: 4
Gjnorthall is on a distinguished road
P0010 is flagged when the crankshaft position sensor is not aligned with the camshaft sensor. Sometimes the problem is easy to solve (connections, sensor fault etc) but sometimes it's caused by wear and stretch in the valve timing gear - this can be expensive to fix. It wouldn't be the first time that someone has avoided an expensive job by disabling the check engine light. In the first instance - delete the code and check if it re-appears. It's very important on VVi engines to change the engine oil at the prescribed intervals - using a good quality oil of the correct specification.
Gjnorthall is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 09:11 AM   #16 (permalink)
Hi again. Could anyone point me to where i can find the Camshaft Sensor?
Old 08-08-2019, 09:15 AM   #17 (permalink)
aquanaut20's Avatar
Have you confirmed it faulty, or just guessing based on a code...??
It requires a scope to verify CAM/Crank correlation... Wave form?
... Philip
.... Philip
Old 08-08-2019, 09:25 AM   #18 (permalink)
It's just based off the code on the reader, it says P0010 "A" Camshaft Position Actuator Circuit (Bank 1).
I don't know where to find it to see if the wires damaged and i have a new sensor here.
Old 08-08-2019, 02:08 PM   #19 (permalink)
Parts cannon approach, this doesn't work, and gets very expensive very quickly.
I believe that people interpret this as a cam sensor code, and can be caused by faulty cam sensor, a faulty VVT solenoid, blocked oil filter screens in the passages, or a faulty VVT actuator.
in any case, further diagnosis is required, and in this case will require a scope to compare timing and drive waveforms to the cam actuators and the cam sensor output and the CKP sensor reference
P0010 is a generic OBD-II code indicating an issue with the engine control module (ECM) detecting a variation in the mechanical timing between the crankshaft and bank 1 camshaft. The timing issue is typically detected during higher RPMs of the engine when the ECM attempts to adjust valve lift or timing during higher speeds.
or in this case, cam timing via the VVT solenoid. ECM is calling for cam timing adjustment and not seeing it.
2008 Swift M15A
Old 08-08-2019, 02:22 PM   #20 (permalink)
VVT Solenoid, where is that located? Watched a lot of YouTube videos about that one associated with the code. I don't know anyone with a scope, might just drive it to the mechanics then.. Thanks for heling out. 👍😊
