Vibration in front end - Suzuki Forums: Suzuki Forum Site
Old 09-28-2013, 09:43 AM   #1 (permalink)
brasco18 is on a distinguished road
Default Vibration in front end
I just recently installed a new half axle and a new tie rod end. There is now an inconsistent vibration that happens at around 60mph. It isn't consistent; sometimes it happens, sometimes it doesn't. It doesn't seem to affect the steering wheel, meaning that, when it vibrates, I don't feel it in my hands.
Is it possible I could damage the CV joint putting the axle in? Would a damaged CV joint have these symptoms?
brasco18 is offline   Reply With Quote Quick reply to this message
Old 10-01-2013, 02:16 PM   #2 (permalink)
atc250r
It's very possible it's a bad CV joint. All too many rebuilders just put new boots and new grease on a worn out joint.
Suzuki Automobiles - Turning regular Americans into mechanics since 1985
2005 Forenza S Wagon - Commuter
atc250r is offline   Reply With Quote Quick reply to this message
Old 10-02-2013, 01:25 PM   #3 (permalink)
The half axle is suppose to be brand new, unused.
Old 10-02-2013, 05:21 PM   #4 (permalink)
Gallery: 11
hi. theres a few possibilities. maybe your wheels need to be balanced. you could have dented a wheel. could be that a bolt is loose. usually when it happens around 60mph it has something to do with a wheel. you should have them checked out. let us know what you find out.
Old 10-14-2013, 11:11 AM   #5 (permalink)
I had it in for an alignment. They did find that the strut bolts were a bit loose. So, with the alignment done, and the strut bolts now tight, the vibration is the same. If anything, It now pulls ever so slightly to the left.
The vibration is the most noticeable at about 15 mph up to about 30 mph. No clunking. Just a slow, very apparent vibration, pulsation. It is not all that noticeable from 30 to 65. At around 70 I notice it again, but now a fast vibration, and there is a low level hum.
On a side note, and a funny story, I wanted to see the axle while it was in motion. I decided to mount a GoPro camera in the wheel well, hoping to video the cv joint. I zip tied the camera a bolt that was out of the way of the wheel (I don't know how to describe what this bolt does without being confusing. Suffice to say it seemed safe). To mount the camera, I had to remove the wheel. I guess there was more space with the weight off the wheel. Once the car was back on the ground, things got a bit tight. I made it about two blocks, when I hit a bump and I heard a clunk. I pulled over to see if I had lost the camera. Turns out the camera got pinched between the lower control arm and the sway bar (I think). It snapped the camera off the mount. Luckily, the camera fell right onto the control arm and stayed there.
Watching the video is kind of neat. Unfortunately, it was late in the afternoon, so there wasn't enough ambient light in the wheel well. Thus, I wasn't able to see anything besides silhouettes. I will probably try again, but will find a way to mount the camera in a better place, once my new camera case comes in the mail
Old 10-15-2013, 02:19 AM   #6 (permalink)
Gallery: 11
wow sorry to hear about the camera hope it was ok? sounding more like your wheels might have a bend or need to be balanced. you could try to rotate the wheels and see if the vibration changes location and the pulling stops. let us know what you find out
Old 10-15-2013, 04:21 PM   #7 (permalink)
If a rim was bent/warped, wouldn't the vibration be noticeable through the entire range? Why would it go away when I get above 30, only to come back at 70?
Just to stir the pot a bit, could it be a wheel bearing? It seems to be quite a coincidence for a bearing to fail right after I put a new axle in.
Old 10-15-2013, 04:44 PM   #8 (permalink)
Gallery: 11
Well I'll be honest, and I'm not trying to be a jerk, that's just how it works when you have a bent rim. I guess it must have something to do with speed, revolutions per min, I don't know the specifics of why it works like that. I guess it could be a bearing but why wouldn't the bearing so it all the time? The easiest thing to do is just swap the front and rear rims and see if it goes away.
Old 10-16-2013, 08:34 AM   #9 (permalink)
I think I'm getting too specific about the vibration. Truth is, it starts at low speed, and gets faster with speed, until, at around 70, it starts to make a humming noise.
I may be hung up on the whole axle thing. It may be possible that there was a break-in period with the new axle where it made some noise. And during that time, something else may have gone wrong, like an imbalanced tire, bent rim, bad bearing...
I am going to start by rotating the tires. I will check their balance as well.
If I was outside looking in, I, too, would think it was a bent rim.
What does a bad bearing do? What are the signs of a bad bearing?
Old 10-17-2013, 09:09 PM   #10 (permalink)
Gallery: 11
well a bad wheel is the cheapest and easiest to diagnose. it also fits your description of the problem. let us know what you find out and we'll go from there
