Ball Joint - Suzuki Forums: Suzuki Forum Site
Old 09-05-2013, 11:49 AM   #1 (permalink)
brasco18 is on a distinguished road
Default Ball Joint
I got a 2005 Suzuki Forenza S wagon. I need to replace the ball joint on the front right wheel. It seems like a pretty straight forward process. I will need to drill out the rivets to do it. My question is, is there an easy way to remove the ball joint shaft from the knuckle?
brasco18 is offline   Reply With Quote Quick reply to this message
Old 09-05-2013, 11:08 PM   #2 (permalink)
Gallery: 11
hi. not sure if this is what your asking but, the whole part that you remove by drilling the rivets is whats replaced. you just need to bolt the new one into place.
Old 09-06-2013, 06:09 AM   #3 (permalink)
Like shown here.
2005 SUZUKI FORENZA Ball Joint
And you are lucky, as a lot of Zuki models require replacing the whole lower control ARM, as the ball joint is integral to it and not supplied separately. And that is my assuming that the S WAGON is the same config as the sedan.
And no, you can't remove the shaft from the knuckle. Not sure why one would want to even attempt that, unless I don't understand the question either.
Old 09-06-2013, 09:53 AM   #4 (permalink)
exist3nce's Avatar
Gallery: 9
Unless he means to remove the entire control arm? That does make the job a little easier... thats what I did lol.
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 09-08-2013, 08:59 AM   #5 (permalink)
Yes, the picture posted above is exactly what I am installing. It is a bolt on kind. The original is riveted onto the control arm. I was hoping someone had replaced the ball joint without removing the control arm. The ball joint shaft has to come out of the knuckle. Otherwise you would have to replace the whole knuckle, which would make sense.
I just aquired a pickle fork bar. I will let you know how that goes.
Old 09-08-2013, 02:24 PM   #6 (permalink)
My last post, I mistyped. I meant to say it 'wouldn't' make sense to have to replace the whole knuckle if replacing the ball joint. And I meant to say I just 'acquired' a pickle fork 'pry' bar.
Old 09-08-2013, 02:29 PM   #7 (permalink)
Gallery: 11
yeah, the way to do it is to grind off or drill out the rivets and bolt on the new piece
Old 09-08-2013, 09:43 PM   #8 (permalink)
Well, the pickle fork pry bar worked like a charm to separate the bolt from the knuckle. Unfortunately, I had a mishap drilling out the rivets. I pushed too hard and went straight through the rivet, put a hole in the CV boot! Needless to say, I was not very happy. I read on a different post somewhere that the person fixed a similar problem with a inner tube patch. I decided to try it. The placement of the hole was right in the crease so it was really tricky to get the patch to sit right. I won't know if it will hold until I get the ball joint replaced. Has anyone replace a VB boot before?
Old 10-14-2013, 11:46 AM   #9 (permalink)
Just following up on my own thread. I did try the bicycle patch. It did work for a few days, but eventually started leaking again. I also tried rtv sealant (gasket sealant). That didn't work either.
I think that if the hole had been on a ridge of the boot, the bicycle patch would have worked. However, since it was more in a crease, the patch was never able to seal properly.
After exploring options, the easiest thing to do was replace the entire axle. There are slip boots available, but I didn't have time to figure it out.
Moral to the story: be very careful when doing work in the wheel well so as not to damage the cv boot!
