2006 forenza transmission problem - Suzuki Forums: Suzuki Forum Site
Old 05-31-2009, 09:01 PM   #1 (permalink)
chillwill is on a distinguished road
Default 2006 forenza transmission problem
my 2006 forenza from time to time will jerk hard when going from park to reverse, and the dash display that indicates which gear you are in (park, reverse, drive etc) will be scrambled, the car will still move while in reverse, but when you put it in drive it will jerk hard again and the will move but it revs higher than normal and will not change gears, but you can put the car back in park and turn the car off, wait about 2 minutes then restart the car and the car runs and shifts normally. has anybody had this problem before and if so what was the fix for it, any help would be appreciated.
chillwill is offline   Reply With Quote Quick reply to this message
Old 05-31-2009, 11:38 PM   #2 (permalink)
zstalker's Avatar
zstalker is on a distinguished road
Transmission range sensor. Search, I'd bet there are a couple threads on it.
~Erik~
Suzuki Gold-level certified technician
dealership lead Suzuki technician
ASE Master Technician
zstalker is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 05:50 PM   #3 (permalink)
thanks eric, i just came from autozone because the check engine light was on and the code that came up was p0705 which is the transmission range sensor circuit, thanks for your prompt reply, and is this a dealer only item.
Old 06-01-2009, 09:53 PM   #4 (permalink)
zstalker's Avatar
I'd be willing to bet they're dealer only, but they're less than $50, so not too terrible..
~Erik~
Old 06-12-2009, 10:46 AM   #5 (permalink)
JagerGirl13 is on a distinguished road
Angry Transmission Range Selector Switch
I have an 06' Forenza and my car has been doing the same exact thing as your car. Its been doing it for about a month. I have 64k miles on my car.
I just took my car to the dealership where I purchased it. It cost me $69 to have them plug it in and give me a diagnostic. They told me it was the range switch, which is not under the 100k warranty. The dealership wants to charge me $276 plus tax to have it fixed. Its complete bullshit! I found a local repair shop that will fix it for $120 plus tax. So do yourself a favor and DO NOT take your car to the dealership for repair!
JagerGirl13 is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 01:00 PM   #6 (permalink)
marksherrod is on a distinguished road
Default It works....
I had the same problem and it was annoying. But I got on the internet and found this forum (thank God!). They recommended the Transmission range sensor, bought one from OEM Suzuki Parts (total cost was $45.00), slapped it on (very simple installation) and no more problems.
Thanks for that help, forum!!!
marksherrod is offline   Reply With Quote Quick reply to this message
Old 08-17-2009, 09:19 AM   #7 (permalink)
Big Daddy is on a distinguished road
Lightbulb heads up on electronics issues
being a forenza owner i see your point, being a dealership mechanic for gm/chevy, i will say this about dealership work....
theres many reasons why sensors go out,
1) worn out... happens ALOT
2)moisture/dirt RARELY a plug will not seal properly and cause connections to corrode(rust) and will cause a circuit failure (loss of power to the sensor,etc) causing a code
3) my all time favorite .... electrical, ive seen rare cases where a voltage is not what its supposed to be and caused the initial failure AND damaged the replacement parts
i HATE spending money fixing things, and I HATE the thought of someone else's hands on MY CAR....
but this is the wife's car, and its going to be fixed right, i feel your pain when it comes to problems, i work on trucks that cost well over $100,000 and am used to the concerns my customers have. but if there's a known issue (there are hordes of databases that customers are not privy to that document everything from bad wiring connections, to fuel line issues etc that only dealers have access to) as a mechanic, it would suck for me to replace a part, tell wifey that is fixed, and have something else fail because i didnt know that x voltage was supposed to be yy.y instead of zz.z or that theres some sealant required on the connection to ensure that elemental effects dont damage the connections
and quite frankly, $276 for a sensor replacement.... is a heck of alot cheaper than $3000 for a new transmission, etc
i have yet to get rid of a car w/ less than 340,000miles so... take advice for what it is.. advice, you dont have to do anything anyone tells ya, but from both sides of the fence, ive seen some ugly ugly problems that could have been avoided by paying the premium and letting the Pro's do their thing
Big Daddy is offline   Reply With Quote Quick reply to this message
Old 08-17-2009, 11:47 AM   #8 (permalink)
Mzauthentic is on a distinguished road
I have the exact same problem and I have a 07 forenza...I thought it was somethig I was doing wrong
Mzauthentic is offline   Reply With Quote Quick reply to this message
Old 08-17-2009, 12:26 PM   #9 (permalink)
Exclamation
just got off the phone w. the service mgr @ Planet Suzuki (i bought it from there, they treat me right=PROMO!!)
according Mr Payton, you yourself CAN change out the sensor, HOWEVER, you still need a Suzuki Tech 2 programming computer to program the TCM (Transmission Control Module) to accept the new sensor (new OBDII systems sometimes require the serial # of the replacement module,.. this is common w. GM vehicles.. and oh by the way.. the 06's are running GM powertrains :-D)
so... save yourself the time of swapping out the part and driving 25mph down the road to your nearest dealership... just pay the money and let them do it, apparently its a very well known problem and they can do it in one step (unless you want to buy the Tech2 Suzuki scanner, last one i priced.. was just under $4,200 brand new from suzuki, or $2000 for a refurb).... but then u still gotta pay for the software subscription $500/yr, and you have to learn how to use a Tech2!
Old 08-23-2009, 08:28 PM   #10 (permalink)
zstalker's Avatar
Incorrect. The only time the Tech2 is required to initialize anything related to the transmission is when the TCM or the transmission itself is replaced, or as (basically) part of troubleshooting shift ptoblems. Data/trouble code reading or control functions are another story, but you do not need the Tech2 to replace the range sensor. Just make sure the retaining bolts are centered in the slotted holes in the sensor (supposed to be for adjustment, but centered has worked every time so far), and make sure the sensor goes on the shaft cleanly, as not to destroy the splines on the inside of the new sensor. Not really that hard, especially for someone who's a mechanic anyways. Big Daddy, you'll probably be quite familiar with this car, as the Aveo is just a tiny Forenza/Reno.
~Erik~
