Thermostats - Suzuki Forums: Suzuki Forum Site
Old 05-29-2009, 09:56 AM   #1 (permalink)
ihatemycar is on a distinguished road
Default Thermostats
Hi
I have an '04 Forenza, and the thermostat is causing my check engine light to go on. I just got laid off and don't have the $150 the dealer wants for the thermostat/housing part. Anybody know how else to maybe get around it? The car is due for inspection and I was told it will fail as of right now cue to the thermostat. Any suggestions would be great.
ihatemycar is offline   Reply With Quote Quick reply to this message
Old 06-06-2009, 04:25 PM   #2 (permalink)
Shenanigans
i'm looking for a cheaper alternative also, I vaguely remeber hearing something a while back about being able to just replace the internals of our thermostat instead of the entire thing.
Can anyone help us out here?
Shenanigans is offline   Reply With Quote Quick reply to this message
Old 09-05-2009, 08:50 PM   #3 (permalink)
Nite-Mare is on a distinguished road
Bump. I am going to need one coming up...
I am also maybe looking for a cooler thermostat.
Nite-Mare is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 11:05 AM   #4 (permalink)
johnhumid is on a distinguished road
Just replace the internals of your thermostat instead of the entire thing. find those parts that is needed...
_________________
Humidifier filters
johnhumid is offline   Reply With Quote Quick reply to this message
Old 09-07-2009, 10:50 AM   #5 (permalink)
killergopher is on a distinguished road
I had the same problem, after going to autozone and buying the thermostate they say is for a forenza and pulling the houseing off i quickly realized they are wrong. I looked all over the place for about 2 weeks for the internals only and they do not sell them new, you need to buy the entire housing/thermostat from suzuki only, no aftermarket place, at least none that I spoke to can get one. I did not check one place which actually usually has suzuki parts in stock for CHEAP, it is rockauto.com. I have gotten a lot of things from them for less then anywhere and there customer service was AMAZING. I got a new o2 sensor from them which was out of stock but the website showed it in stock so they called me, gave me the more expensive version for the same price, bumped my shipping up to next day also for free.
And no I do not work for them just think they are great for suzuki owners looking for something other then going to the factory for parts.
killergopher is offline   Reply With Quote Quick reply to this message
Old 09-08-2009, 09:47 PM   #6 (permalink)
Looking at that site, looks pretty good. BBB says there are good too...
Thanks for the info killergopher!!
Old 09-09-2009, 06:52 PM   #7 (permalink)
yeah no problem, i know how much of a pain in the butt it can be trying to find parts for a forenza and this place saves so many head aches figured i should pass it on
Old 11-03-2009, 12:04 PM   #8 (permalink)
KenBradley is on a distinguished road
Default Thermostat AVAILABLE for Forenza & Reno - alternative to dealer/factory parts
I understand your frustration with the thermostat. Was having the hardest time finding a replacement thermostat for my 2006 Forenza, and refused to go to the dealer and pay $116 for thermostat, which is prone to failure anyway. Kept getting a P0128 Check Engine Code all last winter and the car ran too cold often and I had very little cabin heat on certain days. Knew I needed to replace the thermostat, but didn't want to put the same factory garbage back in the car.
This ought to help fellow Forenza & Reno owners. I actually have high-quality thermostats in stock, mfg'd by an OE & aftermarket mfg. (made in Germany). These are much higher quality than the GM/Suzuki ones, which are prone to sticking open. It is a complete thermostat/housing/& gasket assy. Dealer cost for parts alone is $116.91. These are available for only $30.95/set. See: eBay item #11044976686
Suzuki Forenza & Reno Thermostat, Housing & Gasket:eBay Motors (item 110449766986 end time Nov-23-09 20:16:26 PST)
FYI - there is also a 180deg. thermostat version available (much more difficult to obtain). I know some people were looking for a colder version than factory. These are only $45. Hope this helps save a trip to the dealer and saves everyone some $ & frustration.
Unfortunately, you can't just replace the thermostat internals / mechanism. Comes complete and installed in a new aluminum housing.
I also have polished stainless steel hex bolts to replace the factory reverse-torx bolts - won't have to use special tools to remove again, and these won't ever rust or snap inside the engine block.
Ken
KenBradley is offline   Reply With Quote Quick reply to this message
Old 11-03-2009, 06:06 PM   #9 (permalink)
Gallery: 11
hey thanks for the info, very helpfull
Old 11-04-2009, 11:44 AM   #10 (permalink)
exist3nce's Avatar
Gallery: 9
I was looking for colder thermostats on ebay and came across kenbradley's posting. I was looking for the 180 degree version which he did not have in stock. He spent some time and trouble to try to source them out for me, and has very good communication and customer service. I would highly reccomend buying from him if you are looking for thermostats!
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
