High Beams - Suzuki Forums: Suzuki Forum Site
Old 05-01-2009, 08:47 PM   #1 (permalink)
fatthogg is on a distinguished road
Default High Beams
I installed a new column lever/ switch. Low beams and daytime running lights are fine. High beams work when lever is pulled back, but not when it is in the High Beam position. Is there another dimmer switch located elswhere under the dash? please help!
fatthogg is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 09:42 AM   #2 (permalink)
somewacko is on a distinguished road
Im having the exact same problem.
Did you end up fixing it? Does anyone else know? I replaced the Combo switch and still the high beams don't work when i push the lever forward.
somewacko is offline   Reply With Quote Quick reply to this message
Old 08-29-2009, 04:29 PM   #3 (permalink)
ShadowDog's Avatar
ShadowDog is an unknown quantity at this point
Just to cover the bases, you have the headlamp switch all the way in the 'ON' position when pushing the control stalk forward to engauge highbeams, correct?
I only ask because I had to inform two people that the highbeams will work at any time when pulling the control stalk back, but only work with the control stalk in its fixed position with the headlamp switch turned on past the park lamps.
Sounds crazy to have to say this, but I figured I should ask.
ShadowDog is offline   Reply With Quote Quick reply to this message
Old 09-22-2009, 11:54 AM   #4 (permalink)
Well maybe the issue is that the headlamps arnt turning on when they are turned past the park lamps, as you say...
I do have DLR and all interior lights come on, but high beams do not. Infact, when I turn on all the lights and push the lever forward, there is a slight, but noticible flash - but no highbeams.
any ideas?
Old 10-05-2009, 06:50 PM   #5 (permalink)
You need to check the wire harness under the left front fender. Shorting/Open issues under the fuse box and near the point of entry to the body all up over the LF inner fender.
Old 10-28-2009, 10:45 AM   #6 (permalink)
I checked the wiring and the fuse box, still the issue persists. Has anyone solved such a problem before?
Old 10-28-2009, 11:26 AM   #7 (permalink)
Gaguy24 is on a distinguished road
I know this is a stupid thing to ask, but have you checked to see if your high beam bulb is burned out? Cause on mine I just swap the low beam/ high beam lamps till I get enough saved up for 4 bulbs.
Cause that's what happened to me, high beam bulbs went out after I flashed this semi repetitively to get outta my way got to the nearest walmart and swapped them and sure enough they worked. Maybe that's all that's wrong with it *crosses fingers*
Gaguy24 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 11:30 AM   #8 (permalink)
The High beams work when i pulll the lever towards me (Flashing). But they do not work when I push the lever forward. The DLRs stay on.
Old 10-30-2009, 10:49 PM   #9 (permalink)
It has to be in the switch or harness between the switch and fuse box.
Old 02-15-2014, 10:47 PM   #10 (permalink)
kiwipop is on a distinguished road
Did you ever solve your lack of highbeams issue?
Thanks.
kiwipop is offline   Reply With Quote Quick reply to this message
