Reno. Cat converter - Suzuki Forums: Suzuki Forum Site
Old 03-17-2009, 04:06 PM   #1 (permalink)
rustik23's Avatar
rustik23 is on a distinguished road
Default Reno. Cat converter
Engine misifres. Even tho spark plugs, and wires are changed.
Went to mechanic, he says i need to change my Catalytic converter.
Has anyone done it? And how much does it cost?
the code is: 0420 Catalyst system efficiency below threshold bank 1.
Another small problems:
My seat broke, YEA the seat, Is it difficult to install it??? Like completely to put the brand new one.
And The airbag sign went on. What might cause the problem?
Thank you. Very much.
This is the only site that i find very useful information about suzuki.
Thank x a lot.
rustik23 is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 05:27 PM   #2 (permalink)
lamborgini112 is on a distinguished road
i think your the first bad cat on here thati've read about... however seeing how much space there is next to the CAT and how easy it is to put in a test pipe. If you can fine the replacment cat, unbolt the exhuast heatshield ( a can of WD40 will almost be necessary, then you will see the top bolts for the CAT, undo these. Then go down under the car and you'll be looking at the bottom of the CAT and undo the bolts. I had to hit mine out with a love tap from a hammer but after than wedge the new one in, bolt it back up and then get someone to erase the code from your ECM. Easy peezy lemon squeezy,
As for the Seat, if you have a new one, slide the old one all the way forward and undo the rear bolts (one on each corner, then slide it all the way back and undo the front two bolts. the seat will want to fall backwards, let it. Then undo the Two wires (one for the seat belt and the other for the airbag) now you can remove the seat. From here i put a carbon seat in but i imagine the principle is the same. Looking at the bottom of the seat you should be able to transfer the seat rails over to the new seat with the OEM hardware. Then reverse the process for reinstallation. (My friend says you should disconnect the battery to prevent the air bag going off but i never have any problems.
As for the air bag light coming on, that's a problem that plagues these cars. I usually squirt some electrical connector cleaner from Walmart in to the plugs before reconnecting them and i rarely have issue.
Hope that helps.
lamborgini112 is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 06:15 PM   #3 (permalink)
rustik23's Avatar
So i went to a delaer and he says cat coverter costs 1250. 1250?????
THen i called to suzuki they say if you live in NJ ur warranty on emission till 80000 or 5 years. IF you live in NY the warranty is 50000 miles or 3 years. Since my car is registered in NJ it should nt be a problem. Well see hwo it goes when i go to the delaer next week.
Old 03-18-2009, 06:26 PM   #4 (permalink)
Yeah the CAT really is that much....sooo stupid. I have an extra performance HI-flow CAT that is supposed to still pass emissions that I would sell for $150 shipped.
Old 03-18-2009, 11:28 PM   #5 (permalink)
try Car-Part.com--Used Auto Parts Market too maybe you can get a lightly used one for a decent price. I didn't take the time to look.
Old 03-19-2009, 12:51 PM   #6 (permalink)
exist3nce's Avatar
Gallery: 9
I also haven't heard of the cat going bad so fast, especially without any major mods. The OEM cats are ridiculously expensive....its like that for most new cars. I kind of doubt you will find a used cat on car-part.com or at any other wreckers (there is a reason they don't sell used cats, but I can't seem to remember it right now lol).
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 03-19-2009, 01:36 PM   #7 (permalink)
Gallery: 11
i might be wrong but i believe the cat should be covered by warenty. i think suzuki extended the exhaust warenty but i might be wrong. its also legal to change the cat to an aftermarket equivelent as long as the original cat has gone bad, i think this is true for all 50 states. just get youself a good aftermarket cat. any shop can replace it and it should only cost,for a good one, a couple of hundred dollars.
Old 03-19-2009, 01:38 PM   #8 (permalink)
Gallery: 11
oh yeah i exist3nce is right i dont think they will sell you a used one but you might get lucky.
Old 03-19-2009, 09:25 PM   #9 (permalink)
rustik23's Avatar
Yea i was told that used cats are illegal to sell. anyways hope it will be covered under warranty.
7even this question since you live in NY, does your radio have good reception on 87.7 FM???
Cause mine always with some statics. I was wondering is it my radio or antenna, or most renos are like this???
Thanx
Old 03-19-2009, 09:40 PM   #10 (permalink)
zstalker's Avatar
zstalker is on a distinguished road
Catalytic converter failure in the Forenza/Reno isn't exactly common, but does happen from time to time. Check with your dealership to see if it's still covered by the Federal Emissions warranty.
Something to think about, however: Fix the misfire before the new cat is installed. The misfiring is most likely what killed the cat in the first place, and if you just put in a new one, it'll be killed too.
Common things that cause the Forenza/Reno to misfire: Ignition coil failure, fuel injectors dirty, sometimes spark plugs failing will cause a misfire. There are others, but those are the big ones that come to mind.
For the ignition coil, there isn't a whole lot of diagnosis you can do other than swapping on a known good one. For the fuel injectors you can pull the fuel rail off the motor and clean the tips of them with throttle body cleaner spray. That can make a huge difference.
~Erik~
Suzuki Gold-level certified technician
dealership lead Suzuki technician
ASE Master Technician
zstalker is offline   Reply With Quote Quick reply to this message
