All The Basic Info People As About When They First Get On Here - Suzuki Forums: Suzuki Forum Site
Old 12-06-2008, 08:38 PM   #1 (permalink)
pyaaw! is on a distinguished road
Default All The Basic Info People Ask About When They First Get On Here
TO START I am making this thread because I wanted something that people could turn to when they first get on here and need to know some info fast and make it easy to find, I am not saying that i am an expert so if anything on here that i have said is wrong feel free to correct me.
The Forenza and the Reno are the same chassis, suspension and power train. The only real difference is the body and the interior. There are European and Canadian, Korean Models that are the same but named different.
Chasis models
Forenza/ reno: base, convenience, and popular (not available on Reno)
The differences are just the option that come with the car. They all have the same D-Tec 4 cylinder engine. There are only 2 different transmission either automatic or manual, I do not know the model numbers.
RIMS and TIRES:
The lug pattern is 4X114.3mm offset is 40
The stock size rims are 15", they are wrapped in 195/55/R15
If you have the stock tire pressure monitoring system (TPMS) the sensors are built into the valve stems like all GMs
After market Rim sizes are found in this link, there is also a link in there to calculate tire size,
https://www.suzuki-forums.com/suspens...el-advice.html
LOWERING SPRINGS:
There are very limited options for our vehicles you have APEX springs and use stock struts or go all out and get variant coilovers
COLD AIR INTAKES
BMS CAI REVIEWS
https://www.suzuki-forums.com/forenza...ir-intake.html
RANDOM CAI
https://www.suzuki-forums.com/forenza...cheap-cai.html
SPARK PLUGS:
The Spark Plugs NGK-BKR6EK, BOSH-FLR8LDCU there are others but these are the 2 closest to stock (im sure the stock one is a bosh)
How to change them https://www.suzuki-forums.com/forenza...ark-plugs.html
How to change the SHIFT KNOB: https://www.suzuki-forums.com/interio...b-removel.html
SO these are just a few things that I have come up with by doing basic searches. If you have something else that you want to add Go right ahead, please add a linkback to the thread you found the info on, thankyou.
If you are interested in purchasing anything for our cars KinkyLlama has a lot of parts up for sale most of the time.
pyaaw! is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 12:08 AM   #2 (permalink)
Forenza Owner's Avatar
Forenza Owner is on a distinguished road
Nice Work pyaww!
I don't have anything to add vehicle wise.
If you're new tell us about how satisfied or dissasified with your Forenza/Reno by posting in this thread:
We all like to know how these cars work for you or not work for you.
https://www.suzuki-forums.com/general...ur-suzuki.html
Forenza Owner is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 03:36 AM   #3 (permalink)
James L is on a distinguished road
Pyaaw, I read message. I recently got 2004 Forenza with 2.0 engine. I need to know
what aitifreeze to use. It has 30,000 miles and requires a complete aitifreeze change.
The antifreeze in it now is between orange & yellow color.
Thank you very much James L.
James L is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 11:44 AM   #4 (permalink)
James L, As long as it is DEX-COOL approved coolant you are fine.
Old 01-24-2009, 11:18 PM   #5 (permalink)
Thanks pyaaw
Old 01-25-2009, 01:58 AM   #6 (permalink)
Your welcome, glad i can help.
Old 02-05-2009, 02:28 PM   #7 (permalink)
phatslaya is on a distinguished road
Modifications for the car to date
Suspension:
BMS Sway bars (Kinky motorsports, boshart motorsports)
KW Varient 1 coilovers (Kinky motorsports, boshart motorsports)
KW Varient 3 coilovers (Kinky motorsports, boshart motorsports)
Kinky Lower control arm brace (Kinky motorsports)
Intrax Lowering springs
Apex Lowering springs
Engine:
Light weight UD pulley (Kinky motorsports)
BMS cold air intake (Kinky motorsports, boshart motorsports)
Kinky 4-2-1 header (Kinky motorsports)
Magnacore spark plug wires (8mm) (Ebay)
First cat delete pipe (Kinky motorsports or member Syth)
Kinky Mid pipe (Kinky motorsports)
Brakes:
Wilwood Big Brake kit (kinky motorsports)
Stock size slotted/drilled rotors (Ebay)
Green stuff brake pads (Ebay)
Exterior:
Forenza/Optra Lip kit (Kinky motorsports)
Reno/optra 5 Lip kit (Kinky motorsports)
This is all i can think of right now. These parts are designed for the car and are relatively easy to get. Anything beyond these parts,your gonna need to ask and search around. Hope this helps alot of new members
phatslaya is offline   Reply With Quote Quick reply to this message
Old 02-08-2009, 07:12 AM   #8 (permalink)
rplegend is on a distinguished road
Hi, Great info,Maybe you could help. I have a 2004 XL& 4wd just put new tires on. Replaced the orig Bridgestome with KUMO sloris. The orig tire pressure placard states 26 front and 36 back. Biggest range I have ever seen. I want to just go with 32 all around for even wear. any Ideas?
Richard
rplegend is offline   Reply With Quote Quick reply to this message
Old 02-08-2009, 03:13 PM   #9 (permalink)
The big difference in the tire pressure is probably due to it been a 4WD. In most cases you'd keep them at the same pressure so that you can get good gas milage on the road (highway and city driving). Im assuming the 26 is for when your going offroading as a lower tire pressure will help grip on offroad surfaces
Old 02-10-2009, 08:50 AM   #10 (permalink)
Richard
Like phatslaya said, it is most likely for offroading. are the replacement tires the same exact size as the old stock ones?
And 32 sounds fine, basically as long as you are below the maximum rated tire psi for the tire manufacturer (thats cold psi) you are ok. Just keep an eye on your tire wear. because zuki may have the fronts lower psi to keep the front suspension in alignment. not that 1/8 of height will do much in the short run, but over time it may.
what psi did you have in your old ones?
